Noisey Speedometer/Speedometer Cable '89 2WD Manual Trans - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota USENET Discussion Groups > alt.autos.toyota > alt.autos.toyota.trucks
alt.autos.toyota.trucks Toyota Trucks discussion newsgroup.
Old 03-01-2006, 03:08 PM   #1 (permalink)
R.E.Pasco
Guest
Posts: n/a
View R.E.Pasco's Photo Gallery
Ready to turn 190K; in colder weather lots of squealing and minor
speedometer pointer jitter. Sound goes away after a few miles. Noise doesn't
seem to be related to clutch throw-out bearing, moreso to speed of the
vehicle.
How big a deal ($ & time) is it to have the speedometer cable replaced. Is
there any part of the speedometer itself that would cause the initial
squealing?
This truck has received TLC and runs like a top, except for above.
Old 03-02-2006, 02:56 AM   #2 (permalink)
Bruce L. Bergman
Guest
Posts: n/a
View Bruce L. Bergman's Photo Gallery
Re: Noisey Speedometer/Speedometer Cable '89 2WD Manual Trans
On Wed, 01 Mar 2006 20:08:04 GMT, "R.E.Pasco" <richp945@earthlink.net>
wrote:
[color=blue]
>vehicle.
>squealing?
>This truck has received TLC and runs like a top, except for above.[/color]
Squealing sounds like the speedometer head, not the cable, but you
can pull the cable core and clean & lube it to make sure. Lubriplate
would be perfect, but any good white grease will do.
The speedometer cable and casing should be changed as a set, because
the lining on the inside of the casing wears out also and allows the
core to whip. And if the core shreds when it breaks, it really messes
up the inside of the sheath and leaves behind sharp bits of broken
wire. A new cable core in a casing that has had a cable break inside
it may not last long.
I changed the cable on my LandCruiser, it was under $100 and took a
couple hours to remove all the clamps and pull out the old, put in the
new. If anything, the pickups look simpler.
Don't try to change the routing or the slack, and don't kink the new
cable while installing it, or you'll be doing it again soon.
--<< Bruce >>--
Bruce L. Bergman, Woodland Hills (Los Angeles) CA - Desktop
Electrician for Westend Electric - CA726700
5737 Kanan Rd. #359, Agoura CA 91301 (818) 889-9545
Spamtrapped address: Remove the python and the invalid, and use a net.
Old 03-02-2006, 11:21 AM   #3 (permalink)
MrFixit469
Guest
Posts: n/a
View MrFixit469's Photo Gallery
I had the EXACT same problem with mine. I changed the cable and
housing which made NO difference. Turned out to be the speedometer
assembly in the dash, cost me $125.00 to have it repaired at a speedo
shop. If it's just noisy it's probably the cable. If the needle works
erratically like mine, it's probably the speedo assembly.
Old 03-02-2006, 08:56 PM   #4 (permalink)
Bob L
Guest
Posts: n/a
View Bob L's Photo Gallery
"R.E.Pasco" <richp945@earthlink.net> wrote in message
news:EanNf.5917$5M6.5741@newsread2.news.atl.earthlink.net...[color=blue]
> doesn't seem to be related to clutch throw-out bearing, moreso to speed of
> the vehicle.
> Is there any part of the speedometer itself that would cause the initial
> squealing?
>[/color]
I had the same problem a few years ago with my '89 Toyota 4x4 5 spd manual
and took it to the dealer who fixed the problem by changing out the
speedometer cable.
Old 03-03-2006, 04:43 AM   #5 (permalink)
Scotty
Guest
Posts: n/a
View Scotty's Photo Gallery
> the vehicle.
> squealing?
>[/color]
Ive fixed that same issue in my 92 4runner, removed the speedo cable both
ends and while the gearbox end was driven by a battery dril I fed new grease
down the tube till it came out the other end. That was a year ago and teh
noisey speedo and jumping needle havent returned. Took me around an hour and
a half to do the whole job. Oh, then about another half hour to get teh
grease i spilt out of the carpet, DOH!.
Old 03-05-2006, 01:43 PM   #6 (permalink)
Jeff Strickland
Guest
Posts: n/a
View Jeff Strickland's Photo Gallery
You should be able to do this yourself. Some cables will come out of the
cable housing when disconnected from the back of the speedometer head. You
can pull the cable out and clean it, then put it back in. My guess is that
yours is very dirty, and the gunk & muck are causing the noises you hear.
> the vehicle.
> squealing?
>[/color]
Old 03-05-2006, 01:45 PM   #7 (permalink)
Jeff Strickland
Guest
Posts: n/a
"Bruce L. Bergman" <blPYTHONbergman@earthlink.invalid> wrote in message
news:4r8d02d4eo6qon24du0c2ajlnflc950ibs@4ax.com...[color=blue]
> wrote:
>[color=green]
>>doesn't
>>vehicle.
>>Is
>>squealing?
>[/color]
I agree on the fix, but the cable is more likely the cuprit than the head.
Just my opinion ...
[color=blue]
>[/color]
This is all true as well. The only speedo cable that ever gave me trouble
could be fixed by cleaning it, but surely the inside of the sleeve can be
damaged and cause the noise that the OP complains of. I'd clean it first ...
Old 03-06-2006, 04:14 AM   #8 (permalink)
Bruce L. Bergman
Guest
Posts: n/a
On Sun, 5 Mar 2006 10:43:00 -0800, "Jeff Strickland" <crwlr@yahoo.com>
wrote:
[color=blue]
>can pull the cable out and clean it[/color]
And grease it - white lithium grease as a default, unless someone
knows there's something else specified for it.
[color=blue]
>yours is very dirty, and the gunk & muck are causing the noises you hear.[/color]
--<< Bruce >>--
Old 03-07-2006, 08:36 PM   #9 (permalink)
MrFixit469
Guest
Posts: n/a
With mine, the needle didn't work erratically, when I hit 45mph, the
speedo needle jumped to 65 mph and stayed there until I reached 65 mph
then the speedo worked correctly above that.
BB code is Off
Smilies are Off
[IMG] code is Off
89 celica speedo cable leak--help tspieker Celica Forum 6 01-21-2006 12:33 PM
89 leaking oil from speedo cable nomad2012 Archived Corolla threads 2 01-20-2006 04:47 PM
body lift for 89 pickup w/automatic trans 89'TOY 89-95 Toyota Pickup/Hilux 4 07-13-2004 10:36 PM
89 celica speedo cable leak--help tspieker Celica Forum 1 05-11-2004 09:45 PM
Can I use 89 corolla tranny parts for manual tranny conversion for my 93? Protocold Archived Corolla threads 7 02-25-2004 07:32 PM
