Re: 1985 Toyota Land Cruiser
On 3 Mar 2006 10:40:00 -0800, [email]erichagstrom@gmail.com[/email] wrote:
[color=blue]
>Sorry for being so vague. I was just taking a temperature.
>It is in Central Texas. The body is in decent shape (no rust, but could
>use a paint job on the hood) the front bumper is missing, and the rear
>one has a couple of dents. There is some minor body damage to the front
>passenger side panel near the tire. The truck did run, I drove it to
>it's current resting spot. If I put an afternoon into it, it would
>start I am sure. The interior is in pretty decent shape...the center
>console needs to be replaced since the screw holes are blown out. There
>is one small crack in the dash, and the drivers cloth seat is starting
>to tear at the corner. Aside from that the interior just needs a good
>detailing. The transfer case for the 4 wheel drive is tip top, and the
>transmission seems to be in good shape. The engine is leaky, but only
>in one spot. The gaskets need to be changed all the way around. The
>radiator is pretty new, but the exhaust needs to be worked on.
>Again, I would like to get $2000 for the truck, but don't want to leave
>money on the table.[/color]
If you marked it as "$2,000 As-Is" and it's under 200K miles, you're
likely to cause a stampede of people coming over to check it out. And
they're going to mercilessly low-ball you on the price because "It's
not running, and I have no idea what it will take to get it running."
And they would have every right to do it.
I'd strongly suggest you invest a little effort and money in the car
- get a new battery, flush the gas tank if it's been sitting for over
a year, get the car cleaned up and running, buff out the paint and wax
it. Even if you don't fix all the little problems like the oil leak
and the exhaust.
Once it's running and has current tags on it, and people can take it
out for a test-drive or to their mechanic for a check-over, then you
can ask for a lot more - like $5K to $10K depending on the mileage and
other variables. And probably get two or three people bidding.
Smart buyers know LandCruisers, you can push it off a cliff - and
probably walk to the bottom with a few friends for "muscle", tip it
back on it's wheels, check the fluids, and drive it home. Timex ain't
got nothin' on Toyota in the "Takes a lickin' and keeps on tickin'"
race.
--<< Bruce >>--
Bruce L. Bergman, Woodland Hills (Los Angeles) CA - Desktop
Electrician for Westend Electric - CA726700
5737 Kanan Rd. #359, Agoura CA 91301 (818) 889-9545
Spamtrapped address: Remove the python and the invalid, and use a net.
