intermittent automatic transmission problem - 87 4runner. - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota USENET Discussion Groups > alt.autos.toyota > alt.autos.toyota.trucks
alt.autos.toyota.trucks Toyota Trucks discussion newsgroup.
Old 03-07-2006, 05:04 PM   #1 (permalink)
Mark
Guest
Posts: n/a
View Mark's Photo Gallery
I am looking for help diagnosing an intermittent automatic transmission
problem on an 87 4runner.
The symptoms are as follows:
Occasionally after running up through the normal gear range then coming
to a stop, the transmission does not down shift. To get moving, I have
to manually shift down to "1" then up through the gear range.
This will happen just once or twice per trip, sometimes not at all. It
seems to occur whether the overdrive is on or off. The AT fluid level
is correct and the fluid appears to be clean and un-burnt. The engine
is a 22RE (no turbo).
Any help/suggestions are greatly appreciated!
Thanks!
Mark
Old 03-07-2006, 05:23 PM   #2 (permalink)
Ray O
Guest
Posts: n/a
View Ray O's Photo Gallery
Re: intermittent automatic transmission problem - 87 4runner.
"Mark" <ch4@rocketmail.com> wrote in message
news:1141772663.479575.153360@i40g2000cwc.googlegroups.com...[color=blue]
> Thanks!
> Mark
>[/color]
I'd check the connections to the shift solenoids on the transmission case.
Ray O
Old 03-10-2006, 01:26 AM   #3 (permalink)
ch4@rocketmail.com
Guest
Posts: n/a
View ch4@rocketmail.com's Photo Gallery
Thanks Ray,
I checked the connectors and can't find anything obviously wrong. I
just noticed that the overdrive off switch has started blinking when
the downshifting problem occurs. From what I gather this may be an
indicator of a problem with one or more of the solenoids however I
can't find a reference for the OD trouble codes anywhere. Does anyone
happen to know where I might locate these?
Thanks Again For Any Info
Mark
Old 03-10-2006, 11:14 AM   #4 (permalink)
Ray O
Guest
Posts: n/a
news:1141975603.357209.105130@p10g2000cwp.googlegroups.com...[color=blue]
> Thanks Ray,
> Mark[/color]
When the OD off light flashes, it means that the transmission electronic
control unit (ECU) has stored trouble codes. You can go to
[url]http://techinfo.toyota.com/[/url] and purchase daily or annual access to factory
repair manuals.
Ray O
BB code is Off
Smilies are Off
[IMG] code is Off
My 85 Supra automatic transmission started slipping gears! ultraman69 Supra Forum 0 03-05-2006 04:36 AM
1987 Camry SW: Automatic Transmission Problems PDX Slope Pilot 1st & 2nd Generation (1983–1986 & 1987-1991) 0 01-15-2006 07:53 PM
Intermittent Electrical Problem VancouverVan Pre-88 Toyota Pickup/Hilux 10 11-07-2005 12:38 PM
Automatic transmission not shifting slorider Cressida Forum 0 09-18-2005 12:43 PM
Automatic Transmission Problem nnanda Archived Corolla threads 4 02-20-2005 11:51 AM
