T100 fuel pump relay and interia switch - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota USENET Discussion Groups > alt.autos.toyota > alt.autos.toyota.trucks
alt.autos.toyota.trucks Toyota Trucks discussion newsgroup.
Old 03-07-2006, 08:09 PM   #1 (permalink)
Dalton
Guest
Posts: n/a
View Dalton's Photo Gallery
Anyone could tell me where to find Fuel pump relay and fuel pump inertia
switch on my 95 T100. The engine kills when I accelerate hard. By the way
576000 original miles.
Thanks
Old 03-07-2006, 11:33 PM   #2 (permalink)
Mike
Guest
Posts: n/a
View Mike's Photo Gallery
Re: T100 fuel pump relay and interia switch
"Dalton" <durlt@msn.com> wrote in message
news:%ZqPf.47093$Ly6.44393@bignews5.bellsouth.net...[color=blue]
> way 576000 original miles.
> Thanks
>[/color]
The only vehicles that use an inertia switch are fords. The fuel pump
relay should be in the fuse box under the hood but i doubt that is the
problem. Irf the fuel pump relay was bad it wouldn't run at all.
What exactly do you mean when you say "the engine kills when I accelerate
hard". Does the check engine light come on? When was the last time you had a
tune-up done?
Old 03-08-2006, 07:47 PM   #3 (permalink)
Dalton
Guest
Posts: n/a
The truck will cruise at any speed 80 even 90 mph. If I'm cruising 60 or 70
and floor board the truck, it then start to accelerate and will just quit
running. It will also do this if I'm eccelerating from a start.I then have
to put it in neutral and restart the engine. It almost seems like the fuel
has been cut off. Occasionally it will keep running and continue to
accelerate. It doesn't do it at any particular RPM.
"Mike" <mik@localnet.com> wrote in message
news:ALtPf.2081$kg.1825@news02.roc.ny...[color=blue]
> news:%ZqPf.47093$Ly6.44393@bignews5.bellsouth.net...[color=green]
>> Thanks
>>[/color]
> a tune-up done?
>[/color]
Old 03-08-2006, 10:19 PM   #4 (permalink)
Mike
Guest
Posts: n/a
news:9LLPf.64$hJ.41@bignews5.bellsouth.net...[color=blue]
> 70 and floor board the truck, it then start to accelerate and will just
> quit running. It will also do this if I'm eccelerating from a start.I then
> have to put it in neutral and restart the engine. It almost seems like
> the fuel has been cut off. Occasionally it will keep running and
> continue to accelerate. It doesn't do it at any particular RPM.[/color]
So what have you done so far to try and fix the problem ? Does the check
engins light come on ? Scan for codes ? Check fuel pressure ? Check fuel
filter ?
Check for tune up ?
Mike[color=blue]
> news:ALtPf.2081$kg.1825@news02.roc.ny...[color=green]
>> news:%ZqPf.47093$Ly6.44393@bignews5.bellsouth.net...[color=darkred]
>>> Thanks
>>>[/color]
>> accelerate hard". Does the check engine light come on? When was the last
>> time you had a tune-up done?
>>[/color]
>[/color]
BB code is Off
Smilies are Off
[IMG] code is Off
