Glowing red exhaust - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota USENET Discussion Groups > alt.autos.toyota > alt.autos.toyota.trucks
alt.autos.toyota.trucks Toyota Trucks discussion newsgroup.
Old 03-08-2006, 05:03 PM   #1 (permalink)
South4t
Guest
Posts: n/a
View South4t's Photo Gallery
Glowing red exhaust
I just had my '90 Toyota 22RE truck head gasket, timing chain, gears, and
cover replaced. $2800.00 later I have to bring it back 3 times. First time
was to fix coolant and oil leak, bad acceleration, glowing exhaust. Second
time was for oil leak and glowing exhaust. Third time for oil leak and
glowing exhaust. I am now only down to one problem. The exhaust is glowing
red. They adjusted it once to get the acceleration better but still glowing
like a popsicle.
Possible problems I know of: fuel injection not working right (lean or rich),
out of time, or timing gears not installed correctly. I could kick myself in
the butt for not doing this myself.
Have you ran into this before? what did you do to fix it?
thx
Old 03-08-2006, 10:39 PM   #2 (permalink)
Jarhead
Guest
Posts: n/a
View Jarhead's Photo Gallery
Re: Glowing red exhaust
"South4t" <u19472@uwe> wrote in message news:5cf7eb2c31653@uwe...
and
time
Second
glowing
glowing
| like a popsicle.
rich),
myself in
| thx
Only on an old Chevy 6 cyl. The ignition timing was way retarded and
basically was firing into a partially opened exhaust valves. Advanced
the timing to specs and all was okay. I suppose the ignition timing
could be @ or near TDC but the valve timing off and give the same
symptoms.
Jarhead
Old 03-08-2006, 11:18 PM   #3 (permalink)
Mike
Guest
Posts: n/a
View Mike's Photo Gallery
"South4t" <u19472@uwe> wrote in message news:5cf7eb2c31653@uwe...[color=blue]
> glowing
> like a popsicle.
> rich),
> in
> thx[/color]
What part of the exhaust is glowing red, exhaust manifold or converter ?
Old 03-09-2006, 02:51 AM   #4 (permalink)
South4t via CarKB.com
Guest
Posts: n/a
View South4t via CarKB.com's Photo Gallery
The exhaust manifold, not the converter.
Mike wrote:[color=blue][color=green]
>> cover replaced. $2800.00 later I have to bring it back 3 times. First time[/color]
>[quoted text clipped - 14 lines][color=green]
>> thx[/color]
> What part of the exhaust is glowing red, exhaust manifold or converter ?[/color]
Message posted via [url]http://www.carkb.com[/url]
Old 03-09-2006, 04:59 AM   #5 (permalink)
SnoMan
Guest
Posts: n/a
View SnoMan's Photo Gallery
On Thu, 09 Mar 2006 08:51:20 GMT, "South4t via CarKB.com" <u19472@uwe>
wrote:
[color=blue]
>Mike wrote:[color=green][color=darkred]
>>[quoted text clipped - 14 lines][color=darkred]
>>> thx[/color]
>> What part of the exhaust is glowing red, exhaust manifold or converter ?[/color][/color]
They can get pretty hot normally. Usually retarded timing and/or a
lean mixture will cause them to after burn in exhaust manifold and
heat it up further.
Old 03-09-2006, 10:21 AM   #6 (permalink)
Mike
Guest
Posts: n/a
"South4t via CarKB.com" <u19472@uwe> wrote in message
news:5cfd0d645109d@uwe...[color=blue]
> The exhaust manifold, not the converter.[/color]
I would be looking for a lean fuel mixture or a vacuum leak. Ask ckeck
ignition timing and check to be sure the cam timing was set correctly when
the timing chain was replaced.
[color=blue]
>>> time[/color]
>>> thx[/color]
>> ?[/color]
> Message posted via [url]http://www.carkb.com[/url][/color]
Old 03-09-2006, 02:04 PM   #7 (permalink)
Guest
Posts: n/a
Agree....Last time I brought it in they adjusted the timing via distributor
and tweaked it to improve the acceleration. However, it is still there. I did
checkfor vacuum leaks and fixed one but red glow is still there.
If a vacuum line is connected wrong could that also cause this?
What damage can a glowing red exhaust cause?
Bill
>>>> cover replaced. $2800.00 later I have to bring it back 3 times. First[/color][/color]
>[quoted text clipped - 5 lines][color=green][color=darkred]
>>> ?[/color][/color][/color]
Message posted via CarKB.com
[url]http://www.carkb.com/Uwe/Forums.aspx/toyota-truck/200603/1[/url]
Old 03-09-2006, 07:29 PM   #8 (permalink)
Mike
Guest
Posts: n/a
news:5d02eef4f74f8@uwe...[color=blue]
> distributor
> did
> Bill[/color]
Does the truck fuel injection or a carburator ? Did you have this
problem before the repairs ?
[color=blue]
>>[color=darkred]
>>>>>and
>>[quoted text clipped - 5 lines][color=darkred]
>>>> converter
>>>> ?[/color][/color]
> [url]http://www.carkb.com/Uwe/Forums.aspx/toyota-truck/200603/1[/url][/color]
Old 03-09-2006, 07:42 PM   #9 (permalink)
Guest
Posts: n/a
It is fuel injected and I have never had this problem.
>> distributor[/color]
>[quoted text clipped - 6 lines][color=green]
>> Bill[/color]
>>>[/color][/color]
>[quoted text clipped - 9 lines][color=green][color=darkred]
>>>>> converter
Old 03-09-2006, 08:48 PM   #10 (permalink)
Mike
Guest
Posts: n/a
news:5d05e29758124@uwe...[color=blue]
> It is fuel injected and I have never had this problem.[/color]
I would hook it up to a scan tool and check for codes. Also, look at your
sensor values such as O2, coolant temp, air flow.... The folks who did the
timing chain could have damaged a sensor or wiring harness.
Does the check engine light come on when you first turn the key on without
starting the truck ? It should , that is the bulb check. Does it come on or
stay on when the truck is running ?
[color=blue]
>>> distributor[/color]
>>[quoted text clipped - 6 lines][color=darkred]
>>> Bill[/color]
>>[color=darkred]
>>>>[/color]
>>[quoted text clipped - 9 lines][color=darkred]
>>>>>> converter
>>>>>> ?[/color][/color]
>[/color]
Old 03-10-2006, 06:22 AM   #11 (permalink)
Guest
Posts: n/a
The check engine light does come on without starting. After starting/running,
it goes away. IThe last time I had a problem the check engine light came on.
I jumped a few on the test unit and found my O2 sensor down pipe on the
exhaust was bad. This new was $180 but found a brand new in box on ebay for
$40. got lucky.... The only other thing I can think of is the throttle
position sensor may be bad. When testing the O2 sensore the TPS was another
alternative.
How about this. I noticed a small cap associated with the fuel injection
system was broke off. Under the cap on the round post type thing was a small
filter. Would this cap being removed cause any issue?
Bill
>>>> distributor[/color][/color]
>[quoted text clipped - 10 lines][color=green][color=darkred]
>>>>>>> converter
Old 03-10-2006, 06:33 AM   #12 (permalink)
Guest
Posts: n/a
To summarize this string for a glowing red exhaust manifold.
Fuel is being burned in the exhaust probably by the exhaust valves opening
too early and letting the fuel out.
The possible causes are:
1. Timing gears/chain were put on wrong
2. TPS sensor may be bad. (This is not likely since the truck runs well)
3. O2 sensor is bad (Not likely, I replaced it 1.5 years ago with a new one
and check engine light went away)
4. Timing is still off. (They said they adjusted it and performance improved
but glow was still there)
5. Sensor wiring harness may have been damaged. (not likely since the check
engine light operates correctly)
6. Fuel injection problem (not likely since I have never had this problem and
truck runs good)
7. Vacuum leak (Found one could not find anymore)
8. Incorrectly attached vacuum lines
Given the above, the only things left to verify are:
1. Timing gears/chain put on wrong.
Anyone have anything else to add?
Bill
South4t wrote:[color=blue]
>alternative.
>Bill
>>[/color]
>[quoted text clipped - 11 lines][color=green][color=darkred]
>>>>>>>> converter
Old 03-10-2006, 07:11 AM   #13 (permalink)
Elbert
Guest
Posts: n/a
View Elbert's Photo Gallery
On Fri, 10 Mar 2006 12:22:58 GMT, "South4t via CarKB.com" <u19472@uwe>
wrote:
[color=blue]
>alternative.
>Bill
>>[color=darkred]
>>>>> distributor[/color]
>>[quoted text clipped - 10 lines][color=darkred]
>>>>>>>> converter
had this problem one time on GM vehicle ...350 engine, old style HEI
distributor. Turned out to be an issue with the distributor. Replaced
internal part "pole piece ? " and problem fixed. I don't know if
toyota offers service parts for your distributor or not. You need to
know if the truck is advancing the timing as it should. Do not
continue to operate the vehicle with this condition.
I suspect a timming issue somewhere... I would find another shop
to check it out...if the people who made the recent repairs cannot fix
it.
In my case I had made some adjustments to my car at the time (78 z/28)
and I was riding around that evening to see how it performed. I had
been testing the wide open function of the throttle for some time that
night and I stopped and opened the hood while the car was running and
just about had a heart attack. Night time...not much light where I
stopped.....exhaust manifolds partially cherry red. Not good at all.
Elbert
[email]ask@me.com[/email]
Old 03-10-2006, 11:46 PM   #14 (permalink)
Mike
Guest
Posts: n/a
news:5d0b792d1992b@uwe...[color=blue]
> starting/running,
> on.
> for
> another
> alternative.
> small
> filter. Would this cap being removed cause any issue?[/color]
I doubt it. The cap was most likely just a cover for the filter,
[color=blue]
> Bill
>> your
>>the
>> without
>>or
>>[color=darkred]
>>>>> distributor[/color]
>>>>>>>> converter
>>>>>>>> ?[/color][/color]
Old 03-11-2006, 02:37 AM   #15 (permalink)
Scotty
Guest
Posts: n/a
View Scotty's Photo Gallery
news:5d0b91b9118e9@uwe...[color=blue]
> one
> improved
> check
> and
> truck runs good)
>[/color]
I done a similar cockup with my old truck, pulled out the distributor and
put it back one tooth out, does yours have multiple teeth or will it only go
in one way.
BB code is Off
Smilies are Off
[IMG] code is Off
OBDII codes Phi Hardcore Tech and Competition 12 12-24-2011 09:38 AM
Need Red bulbs that stay Red! 5spd V6 ClrTail Camry & Solara Lounge 13 08-16-2004 09:16 PM
exhaust adonis988 MR2 Forum 0 07-13-2004 12:23 PM
Exhaust Components _VVTi_ Camry & Solara Lounge 6 04-16-2004 10:05 AM
Exhaust manifold Glowing Orange BM2KTom Camry & Solara Lounge 8 03-10-2004 10:05 PM
