Special tools for 02 Taco brakes? - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota USENET Discussion Groups > alt.autos.toyota > alt.autos.toyota.trucks
alt.autos.toyota.trucks Toyota Trucks discussion newsgroup.
Old 03-10-2006, 07:10 AM   #1 (permalink)
Doug Kanter
Guest
Posts: n/a
View Doug Kanter's Photo Gallery
I'm considering changing the brake pads on my 02 Tacoma. Never done this
before. I'll be buying the Toyota service manual first. I've got loads of
tools (ratchets, etc), but I'm wondering if there are any oddball tools
required. This expense, if any, will figure into whether I actually do the
job, or take it to my long-time mechanic. Any & all advice is much
appreciated.
Old 03-10-2006, 08:15 AM   #2 (permalink)
Doug Kanter
Guest
Posts: n/a
Re: Special tools for 02 Taco brakes?
Should've mentioned that I'll be doing front brakes first. Rears are fine.
Old 03-10-2006, 08:17 AM   #3 (permalink)
B A R R Y
Guest
Posts: n/a
View B A R R Y's Photo Gallery
Doug Kanter wrote:[color=blue]
> before. I'll be buying the Toyota service manual first.[/color]
For $10, you can get all the applicable documents online @
techinfo.toyota.com.
Old 03-10-2006, 06:37 PM   #4 (permalink)
Radrunner@MTtestdriver.com
Guest
Posts: n/a
View Radrunner@MTtestdriver.com's Photo Gallery
Nothing out of the ordinary is needed to do the job. If you have metric
wrenches, you're good to go. It'll be an easier job if you have
something with which to compress the piston back into the caliper so
the new, thicker pads will fit (a "C" clamp works well), but It's easy
to improvise if you don't have a clamp.
BTW, the rear shoes last a LONG time! You'll go through many pads
before the shoes wear out, at least I do.
Old 03-10-2006, 06:51 PM   #5 (permalink)
Doug Kanter
Guest
Posts: n/a
<Radrunner@MTtestdriver.com> wrote in message
news:1142037441.002607.169110@u72g2000cwu.googlegroups.com...[color=blue]
>[/color]
I could probably get another year out of the front pads, but my 16 year old
son just started driving. Too much on the brakes, not enough planning ahead
(yet). The beatings will begin this weekend. :-)
Old 03-11-2006, 01:16 PM   #6 (permalink)
Guest
Posts: n/a
I'm 56 going on 17 and I'm hard on my brakes too.
For all your Tacoma-related questions, come on over to customtacos.com.
Old 03-12-2006, 11:54 AM   #7 (permalink)
Jeff Strickland
Guest
Posts: n/a
View Jeff Strickland's Photo Gallery
I put new brakes on my daughter's '02 Tacoma PreRunner using just standard
tools that I have in my collection.
It is possible that you may need to have the brake rotors turned in order to
make them true again. I go to my local Kragen or AutoZone stores to have
this work done for $10 per rotor. They will measure the thickness of the
rotor for you to see if it is safe to do this, or if you need to buy new
rotors.
DO NOT STRESS over replacing rotors, this is also done using the standard
tools you should have at home.
Frankly, if you haven't the standard tools needed for this job already, then
perhaps you should reconsider taking the job on. It is reasonable that you
might need a particular size wrench that you haven't got already, but the
job is essentially a very easy one. If you need to buy a set of tools to get
the work done, then you may not have the expertise needed, but if you are
only missing one or two tools, then you should be okay with the job ahead.
"Doug Kanter" <ancientangler@hotmail.com> wrote in message
news:7UeQf.17066$qg.13090@news01.roc.ny...[color=blue]
> appreciated.
>[/color]
Old 03-12-2006, 11:57 AM   #8 (permalink)
Jeff Strickland
Guest
Posts: n/a
>[/color]
I use a pry bar to open the calipers BEFORE I take them off. I accept that
this is considered risky, it is very easy to do correctly and not do any
damage to anything else. I complete one side -- take apart and put back
together -- before I move onto the other side.
[color=blue]
>[/color]
Old 03-12-2006, 12:06 PM   #9 (permalink)
Doug Kanter
Guest
Posts: n/a
"Jeff Strickland" <crwlr@yahoo.com> wrote in message
news:R8udnajv2Nj__YnZRVn-tg@ez2.net...[color=blue]
> to make them true again. I go to my local Kragen or AutoZone stores to
> have this work done for $10 per rotor. They will measure the thickness of
> the rotor for you to see if it is safe to do this, or if you need to buy
> new rotors.
> tools you should have at home.[/color]
So far, there's no wobble at all to the rotors. Not sure about thickness,
though, so I'll probably get them checked. Aside from variations from one
spot to the next, is it acceptable to get a general idea of thickness simply
using calibers?
Old 03-12-2006, 06:39 PM   #10 (permalink)
Jeff Strickland
Guest
Posts: n/a
news:2nZQf.17274$qg.6237@news01.roc.ny...[color=blue]
> news:R8udnajv2Nj__YnZRVn-tg@ez2.net...[color=green]
>> new rotors.
> simply using calibers?
>[/color]
The rotors will be the same all of the way around. They likely do not need
to be turned, but you can measuer them with a simple micrometer that you get
for around $20. Or, you can carry them down the street and the guy with the
lathe will measure them for you. Personally, I think it is always a good
idea to remove the ridges and grooves that form, even if you have no
problems with warped rotors.
I don't recall what you said the mileage was, but if this is the first brake
job, you probably can safely throw in a new set of pads and have another
beer.
Old 03-13-2006, 06:44 AM   #11 (permalink)
Doug Kanter
Guest
Posts: n/a
news:3JidnYUoy_G1IonZRVn-uw@ez2.net...[color=blue]
> news:2nZQf.17274$qg.6237@news01.roc.ny...[color=green]
>> news:R8udnajv2Nj__YnZRVn-tg@ez2.net...[color=darkred]
>>>standard tools that I have in my collection.
>>> order to make them true again. I go to my local Kragen or AutoZone
>>> stores to have this work done for $10 per rotor. They will measure the
>>> thickness of the rotor for you to see if it is safe to do this, or if
>>> you need to buy new rotors.
>>> standard tools you should have at home.[/color]
>>[/color]
> get for around $20. Or, you can carry them down the street and the guy
> with the lathe will measure them for you. Personally, I think it is always
> a good idea to remove the ridges and grooves that form, even if you have
> no problems with warped rotors.
> brake job, you probably can safely throw in a new set of pads and have
> another beer.[/color]
48,000 miles, driven in a style defined as "I can't afford unnecessary
repairs due to recreational nonsense". :-) My biggest concern at the moment
is the leaky edges where the alloy wheels meet the tires.
Old 03-14-2006, 12:40 PM   #12 (permalink)
Doug Kanter
Guest
Posts: n/a
>>[/color]
> another beer.
>[/color]
If I get through this successfuly, I'm gonna figure out a way to send beer
to you through a newsgroup server, in return for your encouraging words. :-)
Old 03-14-2006, 06:05 PM   #13 (permalink)
Jeff Strickland
Guest
Posts: n/a
news:6NdRf.2629$kg.2055@news02.roc.ny...[color=blue]
> news:3JidnYUoy_G1IonZRVn-uw@ez2.net...[color=green]
>> news:2nZQf.17274$qg.6237@news01.roc.ny...[color=darkred]
>>> thickness, though, so I'll probably get them checked. Aside from
>>> variations from one spot to the next, is it acceptable to get a general
>>> idea of thickness simply using calibers?
>>>[/color]
>> need to be turned, but you can measuer them with a simple micrometer that
>> you get for around $20. Or, you can carry them down the street and the
>> guy with the lathe will measure them for you. Personally, I think it is
>> always a good idea to remove the ridges and grooves that form, even if
>> you have no problems with warped rotors.
> moment is the leaky edges where the alloy wheels meet the tires.
>[/color]
With 48k on the clock, the odds are very good that you DO NOT need rotors.
I don't see what leaky edges where the wheels meet the tires has to do with
brakes though ...
And, those leaky edges are called "bead leaks." The tires have beads where
they mate to the rims, when they leak, the term is bead leak.
Old 03-14-2006, 06:09 PM   #14 (permalink)
Jeff Strickland
Guest
Posts: n/a
news:14ERf.2780$kg.1167@news02.roc.ny...[color=blue][color=green]
>>[/color]
>[/color]
I'd prefer you take a few minutes to teach your kid to drive like HE has to
pay for the repairs. ;-)
I subscribe to the driving method you use, I can't afford the repairs so I
use the pedals softly to delay the need for them. My kid drives the same
way, and she doesn't seem to mind. She does do 80 on the freeway, but mostly
as a response to her Survival Instinct, but off the freeway she starts
slowly and brakes early -- two good qualities that all kids should learn.
Old 03-15-2006, 02:00 AM   #15 (permalink)
Doug Kanter
Guest
Posts: n/a
news:0eGdneZfvdzDx4rZ4p2dnA@ez2.net...[color=blue]
> news:6NdRf.2629$kg.2055@news02.roc.ny...[color=green]
>> news:3JidnYUoy_G1IonZRVn-uw@ez2.net...[color=darkred]
>>> that you get for around $20. Or, you can carry them down the street and
>>> the guy with the lathe will measure them for you. Personally, I think it
>>> is always a good idea to remove the ridges and grooves that form, even
>>> if you have no problems with warped rotors.
>>[/color]
> with brakes though ...[/color]
Totally separate issue, just thrown in here for no particular reason.
BB code is Off
Smilies are Off
[IMG] code is Off
Special Service Tools (SST) and Time belt Change. dcbc991 Camry & Solara Lounge 6 01-16-2006 05:12 PM
Newbie Dilemma (Get Taco or Keep 4RNR) Ogie 2nd Generation (2005+) 24 12-05-2005 02:57 PM
Tools needed to work on a camry zoni Camry & Solara Lounge 10 05-05-2004 06:39 PM
