02 tundra cold air intake, tire question - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota USENET Discussion Groups > alt.autos.toyota > alt.autos.toyota.trucks
alt.autos.toyota.trucks Toyota Trucks discussion newsgroup.
Old 03-10-2006, 07:27 PM   #1 (permalink)
Christopher Hollman
Guest
Posts: n/a
View Christopher Hollman's Photo Gallery
where can i buy a cold air intake for my tundra? i've looked and found some
k&n but they are really expensive, any alternatives? can i find one at pep
boys or other retail chain for a reasonable price?
also, how big can i go in terms of tires without a lift? i believe i have
265/70r16 on it right now.
thanks
Old 03-10-2006, 11:25 PM   #2 (permalink)
Bruce L. Bergman
Guest
Posts: n/a
View Bruce L. Bergman's Photo Gallery
Re: 02 tundra cold air intake, tire question
On Fri, 10 Mar 2006 20:27:04 -0500, "Christopher Hollman"
<chrishollman@optonline.net> wrote:
[color=blue]
>boys or other retail chain for a reasonable price?[/color]
You already GET one from the factory - the air filter box already
draws from behind the grille (in front of the radiator where the air
is coldest) for best performance.
(They do the cheap and easy stuff to improve fuel mileage at the
factory - gets those Fleet Fuel Efficiency numbers up.)
The only thing you get from an aftermarket air filter and induction
system is a little lower resistance from bigger and straighter air
passages, and that isn't going to make a lot of difference by itself.
Besides an empty wallet from buying fancy parts, that is...
[color=blue]
>265/70r16 on it right now.[/color]
Don't know, too many variables - 2WD or 4WD, fender flares, etc. Go
to a tire shop and ask, they have charts and to be sure they can fit
one tire on the truck as a test - if it rubs, it won't fit.
But a hint from an old-timer - the higher the truck, the harder it
falls. Lifting it more than two to four inches may look wicked cool
on Cruise Night, but it won't help much while off-roading. And
there's that very serious 'falling over' problem to deal with - you
get sideways, and it's going over
--<< Bruce >>--
Bruce L. Bergman, Woodland Hills (Los Angeles) CA - Desktop
Electrician for Westend Electric - CA726700
5737 Kanan Rd. #359, Agoura CA 91301 (818) 889-9545
Spamtrapped address: Remove the python and the invalid, and use a net.
Old 03-23-2006, 06:01 PM   #3 (permalink)
Ken Shelton
Guest
Posts: n/a
View Ken Shelton's Photo Gallery
Christopher Hollman wrote:[color=blue]
> thanks
>[/color]
Aftermarket air intakes usually take in some hot underhood air...the
stock intake takes in all cold air. The Aftermarket intakes are a
small help at peak rpm, and hurt power at low rpm. Lots of guys at
tundrasolutions.com have taken off aftermarket intakes because of
the loss of power at bottom end.
265/75R16 are no problem. Ask at tundrasolutions.com about bigger
sizes.
Ken
BB code is Off
Smilies are Off
[IMG] code is Off
Question about AEM Cold Air Intake OCAMDDEAD Camry & Solara Lounge 3 09-11-2004 02:58 PM
cold air intake madmax3208 Camry & Solara Lounge 5 08-04-2004 10:21 AM
Ractive Ram Air system. Camry_rider Hardcore Tech and Competition 51 07-23-2004 11:03 AM
Cold air intake 80 bucks. cam2Xrunner Camry & Solara Lounge 7 07-02-2004 02:50 PM
custom cold air intake for 4cyl Gen 2 phat91camryLE 1st & 2nd Generation (1983–1986 & 1987-1991) 0 09-26-2002 06:05 PM
