Re: Tundra GAS MILEAGE improvements
Tdubya wrote:[color=blue]
> I've read here some talk of air ram device that improves gas mileage.
> Has anyone heard or seen this anywhere?
> Anyone know an aftermarket device that will improve gas mileage, even
> a little bit????
> Tdubya[/color]
There is probably nothing you can buy that will more than pay for
itself in fuel savings. A guy on tundrasolutions.com has put
together a ram air kit from some plumbing fittings and offers them
for $99. If it helps, it's only a help at high speeds. Toyota's
engineers did very well in designing the truck, and not much will
make a 5000# truck burn less gas.
Just the basics---
-drive slower
-start from a stop more gently
-don't carry around a lot of heavy junk nor a ladder rack if not needed
-when you next need tires, don't get big, lumpy-tread tires
-try different brands of 87 octane gasoline. See which gives you
the lowest fuel cost per mile
-air up your tires
-do engine maintenance on schedule
Somebody explain how changing the intake makes any difference except
at wide open throttle? The throttle assembly, throttle body and
throttle plate, is doing its job by throttling the air flow to limit
the air going to the engine to match the fuel needed for the power
you want. If the throttle is almost always partly closed, what good
are intake mods?
Ken
