Help! Won't Start After Replacing Fuel Pump Bracket - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota USENET Discussion Groups > alt.autos.toyota > alt.autos.toyota.trucks
alt.autos.toyota.trucks Toyota Trucks discussion newsgroup.
Old 03-13-2006, 09:33 AM   #1 (permalink)
mixedsig@gmail.com
Guest
Posts: n/a
View mixedsig@gmail.com's Photo Gallery
89 4x4 V6 pickup. When I connected the battery after replacing fuel
pump bracket and portion of fuel line, the MIL (Malfunction Indictor
Lamp), head lights and instrument lights began to blink. Head lights
and instrument lights stopped blinking after blinking 40 times, while
MIL kept blinking all the time. I turned the key to ignition position,
and engine wouldn't start. The starter didn't even crank. There was
not a single sign of engine trying to start. I read out the diagnostic
codes from ECM, it's "51".
Any thought about this issue? How to fix? PLEASE PLEASE HELP. Your help
is highly appreciated.
Old 03-13-2006, 10:54 AM   #2 (permalink)
davidj92
Guest
Posts: n/a
View davidj92's Photo Gallery
Re: Help! Won't Start After Replacing Fuel Pump Bracket
[email]mixedsig@gmail.com[/email] wrote:[color=blue]
> help is highly appreciated.[/color]
Google is your friend. Found this:
[url]http://www.off-road.com/toyota/tech/codes/[/url]
scroll down to code 51, there are several possibilities.
Dave
Old 03-13-2006, 01:07 PM   #3 (permalink)
mixedsig@gmail.com
Guest
Posts: n/a
Thanks for the info. I checked the possible causes (except ECM) of
"51", and couldn't find anything abnormal. The repair work I've
done seemed to be unrelated to what the "51" code indicates. The
thing that confuses me is that head light and instrument light will
blink 40 times when I connect battery or open the driver side door,
while the red light below emergency flasher switch keeps blinking as
long as battery is connected. I couldn't find any information about
this symptom. Did anyone see this symptom before? How to fix? Thank you
for your help.
BB code is Off
Smilies are Off
[IMG] code is Off
85 Celica GTS Fuel Pressure Problem Denis Celica Forum 6 03-16-2006 08:11 PM
Fuel pump rewire. 97camryman Camry & Solara Lounge 2 03-08-2006 09:46 AM
Paseo fuel pump pressure ? Donald Tercel, Paseo, Starlet, and Sera Forum 2 04-07-2005 08:25 PM
Fuel pump requirements for 5psi boost (carb'd 4a-c)? O 16581 72452 5 Archived Corolla threads 4 03-17-2004 12:00 PM
Fuel Pump def01 Archived Corolla threads 0 01-27-2004 07:20 PM
