Re: engine overheat and cold air: thermostat?
gp wrote:[color=blue]
> All was fine in that same morning, over the past few days, I have been
> noticing varying lengths of time for the heat to kick in, sometimes
> works well, other times, not so good. The temp guage has been also
> been rising to just below the red and then it drops dramatically to
> well below the normal mark. Have not paid attn to where it leveled
> off.
> I assumed that it was the thermostat that was sticking and that was my
> explanation.
> head gasket sounds expensive. I will start with the thermostat and rad
> flush. Any other advice to rule out the head gasket would be greatly
> appreciated. Some say to run the engine and tab on the thermostat
> housing.[/color]
When you change the thermostat as Mike suggested, also change the radiator
cap. It's a two way valve and it can wear to the point it will stick, the
springs will get weak, gaskets get cracked and etc. It's a cheap item that
gets overlooked a lot when having cooling problems. Be careful and don't
drive it if the temp goes to red, if the head or head gasket isn't bad it
will be if you drive it hot.
When you change the thermostat make sure the hose where connected to
radiator is higher than the connection at the engine, fill rad and overflow
tank to cold mark, run engine with cap off until it gets hot enough to start
flowing coolant. Shut off, install rad cap and let it cool down, this should
make sure you don't get any air pockets in rad.
HTH, Dave
