1994 Toyota 4x4 develops miss after warm up - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota USENET Discussion Groups > alt.autos.toyota > alt.autos.toyota.trucks
alt.autos.toyota.trucks Toyota Trucks discussion newsgroup.
Old 03-23-2006, 06:42 AM   #1 (permalink)
Brad
Guest
Posts: n/a
View Brad's Photo Gallery
I recently installed a new/rebuilt long block into my 1994 Toyota 4x4
pickup. During the install I encountered a problem where I was getting
a large amount of water in the oil pan. The problem was an alignment
pin on the timing cover...I had two in one hole. I repaired the leak
and been driving it to work for the past week.
At initial start-up and during 95% of the drive (25 min highway drive)
I experience no problems. When I park and let the truck drop to idle
speed there is a miss. I have noticed it at a stop light after about
20 min worth of driving. It does the same thing on the way home starts
fine idles fine during the first part of my trip, but once i make it
home the miss is back.
Any ideas? Could it be related to residual water in the oil from the
initial leak? Spark plug wires (the only part i didn't replace during
the install of the rebuilt longblock)? Could the valves need adjusting?
Old 03-23-2006, 11:28 AM   #2 (permalink)
Mike
Guest
Posts: n/a
View Mike's Photo Gallery
Re: 1994 Toyota 4x4 develops miss after warm up
"Brad" <stratmaster@peoplepc.com> wrote in message
news:1143117731.210651.90110@z34g2000cwc.googlegroups.com...[color=blue]
>[/color]
It shouldn't be caused by the water leak but you should have changed the
oil if it had water in it.If you haven't already changed the oil, do it NOW.
Water in the oil can cause bearing damage, coolant in the water will speed
up the process. Spark plug wires should cause a miss under load, not at
idle. If the valves were not adjusted properly ( too tight ) it could cause
the symptoms you describe. I would recheck the valve adjustment. Did you
have this problem before the engine swap ?
Old 03-23-2006, 02:49 PM   #3 (permalink)
Brad
Guest
Posts: n/a
<I would recheck the valve adjustment. Did you
<have this problem before the engine swap ?
I did not own the truck before the rebuilt engine was installed, so I
am unsure about the history. I can find out though and that is a good
point.
<If you haven't already changed the oil, do it NOW.
I drained the oil immediately after finding the leak. I also cleaned
off the head before filling the oilpan again. I ran the new oil about
120 miles and changed it again. I am going to run this oil about 500
before the next change.
< I would recheck the valve adjustment.
Do you think it would hurt to wait until the 500 mile mark. I can
retorque and check the valve adjustments at the same time.
Old 03-23-2006, 09:13 PM   #4 (permalink)
Mike
Guest
Posts: n/a
news:1143146965.894113.34820@i40g2000cwc.googlegroups.com...[color=blue]
> point.
>[/color]
It might not hurt to wait but if you are having problems it might be a
good idea to check them sooner.
Old 03-23-2006, 09:46 PM   #5 (permalink)
Brad
Guest
Posts: n/a
< It might not hurt to wait but if you are having problems it might be
a[color=blue]
>good idea to check them sooner.[/color]
I am bringing the core back to the machine/rebuild shop in the morning.
I will run it by them and see what they have to say about it.
Thanks for the tips. I will post my results.
R/
Brad
Old 03-23-2006, 10:07 PM   #6 (permalink)
Brad
Guest
Posts: n/a
Could a bad knock sensor cause this type of problem. Mine is broken
off. I have one on order.
I have no clue what the knock sensor does except for make my check
engine light come on.
Old 03-29-2006, 05:31 AM   #7 (permalink)
Brad
Guest
Posts: n/a
Refresh...
I have put close to 500 miles on the new engine. The miss seems to be
getting less and less noticable, but is still there. I replaced the
broken knock sensor, so I have no check engine light any more.
Also I talked to the machine shop that rebuilt my engine and was told
there was no need to check the valve clearance or retorque the head
bolts....
BB code is Off
Smilies are Off
[IMG] code is Off
TOYOTA ENGINES AND OIL SLUDGE - WALL ST JOURNAL bondobondo General Discussion 99 02-02-2007 06:54 PM
Looking For........... 1radtoy Pre-88 Toyota Pickup/Hilux 9 01-15-2006 10:27 AM
Discount on all TWM Toyota Short Shifters! TWM Performance General Discussion 0 05-19-2005 09:20 AM
87 Toyota 4x4 Reg Cab Project LADUNNKITY Vehicles 0 05-16-2005 08:34 AM
Toyota's global strategy looks inward rolla-XRS Toyota News 7 11-29-2004 03:55 PM
