head gasket or timing belt - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota USENET Discussion Groups > alt.autos.toyota > alt.autos.toyota.trucks
alt.autos.toyota.trucks Toyota Trucks discussion newsgroup.
Old 03-27-2006, 09:48 AM   #1 (permalink)
gp
Guest
Posts: n/a
View gp's Photo Gallery
This is the 3rd post in a series to diagnose an engine overheat for
those interested. I have a 1988 toyota p/u with 190K 22RE fuel
injected.
Engine overheated one day coming from work, cold air blowing in vehicle
and temp gauge nearing red. It turns out there was no/little antifreeze
in rad. At the time, no smoke from tailpipe, antifreeze in oil.
So topped all up and, unfortunately, I have lots of smoke, rough idling
and antifreeze in oil as the oil level is up and you can see some froth
under cap after I cleaned it before driving.
[color=blue]
>From the advice offered so far, seems to say head gasket so I called[/color]
toyota toyota and asked for bolts ($10 each x10 bolts wow), head gasket
about 50.00 and thermostat about 25 with gasket.
The parts person said that it is advisible to buy the set of gaskets
for 170.00 that includes, intake manifold, valve gasket with grommets,
etc. He also suggested that it could be the timing chain that if the
vehicle was making a rattling noise may have rubbed up to something.
Anyway, thinking of taking it to the toyota dealer to have it at least
diagnosed -Any thoughts?, Can I drive it there -about 10Km or should I
have it towed. Finally, can I eliminate or confirm the timing belt
issue with a compression test or other way?
Again, many thanks to all who offer their opinion
Old 03-27-2006, 11:19 AM   #2 (permalink)
EasyE
Guest
Posts: n/a
View EasyE's Photo Gallery
Re: head gasket or timing belt
Unfortunately, it is very common with the 22re that when the Timing chain
starts to begin slack it tends to eat a hole into the inside of the timing
cover .... Check your oil pan for metallic chips and such which would
indicate rubbing.. It certainly sounds to me like a head gasket.... I
have a 94' with a 22re and it did the EXACT same thing... If your going to
replace the head gasket anyway, I would suggest that while it's torn down
you do a few preventative maintenance items which will unfortunately cost
more, but will be worth it.. Planning on doing the work yourself???? If
so, you'll be glad to replace it all at once since you HAVE to pull the head
to get to the timing chain anyway. I would suggest a new Timing
chain/Gears/Tensioner, Oil Pump, and Water Pump.. Replace the Timing cover
also if it looks heavily worn. $50 for a head gasket?? That's pretty
steep... you'd do just as well with a Fel-Pro Gasket from Napa.... and $25
for a thrermostat?? Outrageous... Get that from napa too and save yourself
another 15 bucks.. as far as the head gasket kit... Well.. some you will
need, while others you may not.. But almost always, the manifold gaskets
(intake, and exhaust) will need to be replaced.. I think last time i bought
a complete head gasket kit by Fel-Pro, I think I paid like 80 bucks from
Acme Auto....
If you were buying a sensor, or some other electrical specific part, I would
say buy factory, but gaskets are gaskets, and Fel-Pro makes a damn fine
gasket.
Ian
Toyota-holic
"gp" <gpagmail-news@yahoo.com> wrote in message
news:1143474519.755073.129040@u72g2000cwu.googlegroups.com...[color=blue]
> injected.
>[color=green]
>[/color]
Old 03-27-2006, 11:49 AM   #3 (permalink)
Ray O
Guest
Posts: n/a
View Ray O's Photo Gallery
> injected.
>[/color]
To clarify: are you saying that there is no smoke from the tailpipe but
there is antifreeze in the oil?
[color=blue]
> under cap after I cleaned it before driving.[/color]
Bad sign :-(
[color=blue]
>[color=green]
> vehicle was making a rattling noise may have rubbed up to something.[/color]
You may hear the rattling noise from the front of the engine if the timing
chain tensioner is not working properly.
[color=blue]
> Again, many thanks to all who offer their opinion[/color]
Toyota dealers are probably more knowledgeable about your vehicle than most
independent shops.
Driving it 10 km should be OK as long as there is coolant and oil. BTW,
the 22RE engine has a timing chain, not a timing belt. The only way to
confirm whether the timing chain is a problem is for a knowledgeable person
to listen and remove the timing cover and inspect the chain and tensioner.
Ray O
Old 03-27-2006, 11:50 AM   #4 (permalink)
gp
Guest
Posts: n/a
So you think I should also change water and oil pump while I am there.
I have never done this but planning to arm myself with a manual or 2,
take my time and slowly get down to it. A little anxious about this,
worried about stripping a bolt in there as I take them out. Plan to run
the engine a bit to get warm/hot and use lots of loose nut spray. I
have done some work over the years on my car --even rebuilt some small
engines (lawnmower and stuff) so hoping this works out well. How long
do you think this will take a shop/ a first time do-it-yourselfer?
Ebay has a gasket/bolt set for 80 or so and here is the description,
not sure if better to stick with NAPA. I hear one should go OEM with
the thermostat, but wondering thoughts on gaskets/water pump/oil pump?
I tend to agree with you
This fine head gasket set fits 1985 to 1995 TOYOTA 22R, 22RE, & 22REC,
2.4L inline OHC 4 cylinder engines. The bolts are Pro-Topline, brand
NEW!These are the SAME FINE quality you have come to EXPECT from
EPN™, a Q9002 certified kit, your assurance of quality! This kit
features not only the full NEW head bolt kit, but ALL the gaskets you
will need to do a complete top end overhaul on your Toyota, intake,
exhaust, head gasket, misc gaskets, and INCLUDING the premium VITON oil
seals, even the half moon valve cover ends! As COMPLETE as you will
find! A Special feature is the graphite impregnated core head gasket,
your assurance of a perfect seal, and the premium Viton oil seals, the
same as Toyota uses! S & H adds just $12.00, international is cost of
shipping, Paypal, bank check, or MO is fine, Visa/MC via phone.
Old 03-27-2006, 11:59 AM   #5 (permalink)
gp
Guest
Posts: n/a
Yes, thanks for confirming that it is a chain. I have some auto club
coverage to get it towed. It sounds like while I am there, I should
change much including timing chain, etc.
Thing is, I have had it only 2 years, somewhat possible, it has been
changed. Not sure if I should spend 100$ to get it pro-diagnosed, or
open it up and see what I have got.
So far, my list includes, thermostat, chain, tensioner, many gaskets,
bolts, it has been suggested water pump, oil pump --seems like a long
list, wow!
Old 03-27-2006, 07:20 PM   #6 (permalink)
EasyE
Guest
Posts: n/a
When I had the same issue with my 94' I changed everything... The Timing
Chain on these motors are known to go about every 130,000 miles, so if it
has been changed, well it's overkill, but if it hasn't, it's piece of mind..
I changed everything except the oil pump, for reasons I cannot explain, and
turns out the oil pump had also gone bad, and ended up blowing my engine...
cost me far more to rebuild everything afterward then it would have cost to
originally just replace the oil pump..
Ian
news:1143482364.857441.164960@e56g2000cwe.googlegroups.com...[color=blue]
> list, wow!
>[/color]
Old 03-28-2006, 08:51 AM   #7 (permalink)
gp
Guest
Posts: n/a
Thanks, did you use dealer parts or some aftermarket. I am going with
OEM thermostat, but gaskets, some ebay resources or thinking of NAPA,
as for oil pump and chain, will decide later. I had heard that the
chain lasts longer than that but guess if I am doing it myself, i can
put the savings into some proactive measures.
Old 03-28-2006, 04:43 PM   #8 (permalink)
EasyE
Guest
Posts: n/a
I wouldn't buy a OEM Thermostat... 25 bucks is outrageous for what a
thermostat is.. I bought all my parts on ebay actually.. I did substitute
the head gasket that came with the kit though with a Fel-Pro one.. and
picked up a re-maned oil pump and water pump.. 60,000 miles on the new
motor and it is great..
Ian
news:1143557516.618812.30400@t31g2000cwb.googlegroups.com...[color=blue]
>[/color]
Old 03-28-2006, 04:46 PM   #9 (permalink)
Gary L. Burnore
Guest
Posts: n/a
View Gary L. Burnore's Photo Gallery
On Tue, 28 Mar 2006 22:43:51 GMT, "EasyE" <ezeuconn@hotmail.com>
wrote:
[color=blue]
>thermostat is.. I bought all my parts on ebay actually..[/color]
Hahahahahahahahahahahahahahahahahahahahahahahahahahahahah. Dumbass.
gburnore at DataBasix dot Com
How you look depends on where you go.
Gary L. Burnore | ÝÛ³ºÝ³Þ³ºÝ³³Ýۺݳ޳ºÝ³Ý³Þ³ºÝ³ÝÝÛ³
Official .sig, Accept no substitutes. | ÝÛ³ºÝ³Þ³ºÝ³³Ýۺݳ޳ºÝ³Ý³Þ³ºÝ³ÝÝÛ³
| ÝÛ 0 1 7 2 3 / Ý³Þ 3 7 4 9 3 0 Û³
Black Helicopter Repair Services, Ltd.| Official Proof of Purchase
Old 03-28-2006, 06:53 PM   #10 (permalink)
Ken Pisichko
Guest
Posts: n/a
View Ken Pisichko's Photo Gallery
"Gary L. Burnore" wrote:
[color=blue][color=green]
> gburnore at DataBasix dot Com[/color]
Obviously YOUR mileage has varied - with mine! Keep your expletives to
yourself. Remember to be polite - otherwise folks will think badly of uncouth
language. Got it?
Old 03-28-2006, 11:47 PM   #11 (permalink)
Gary L. Burnore
Guest
Posts: n/a
On Tue, 28 Mar 2006 18:53:15 -0600, Ken Pisichko <kenp@mts.net> wrote:
[color=blue]
>[color=green][color=darkred]
>Obviously YOUR mileage has varied - with mine![/color]
You're likely LYING, but that's ok. You're also a fucking moron.
[color=blue]
>Keep your expletives to yourself.[/color]
Eat shit, bitch.
[color=blue]
> Remember to be polite[/color]
I am being polite, fuckstain.
Old 03-29-2006, 08:54 AM   #12 (permalink)
gp
Guest
Posts: n/a
Thanks, I may need some advice as I dig into it.
Any suggestions on Name brands for gasket sets or locations to buy
from? There are a number on ebay, ex CNS Motors. EPN™, there is
mention of GRAPHITE HADE GASKET, VITON VALVE STEM SEALS so there are a
few sets out there --any cautions? It was suggested I change the head
bolts too.
Here is another ad
NEW!
Several of you asked for a combination like this so here it is!
These are the SAME FINE quality you have come to EXPECT from EPN™, a
This kit features not only the full NEW head bolt kit, but ALL the
gaskets you will need to do a complete top end overhaul on your Toyota,
intake, exhaust, head gasket, misc gaskets, and INCLUDING the premium
VITON oil seals, even the half moon valve cover ends! As COMPLETE as
you will find!
A Special feature is the graphite impregnated core head gasket, your
assurance of a perfect seal, and the premium Viton oil seals, the same
as Toyota uses!
Old 03-29-2006, 04:20 PM   #13 (permalink)
Gary L. Burnore
Guest
Posts: n/a
On 29 Mar 2006 06:54:09 -0800, "gp" <gpagmail-news@yahoo.com> wrote:
[color=blue]
>[/color]
One is to be sure to replace the timing belt and water pump while
you're doing the head gasket. No sense going back in.
Old 04-05-2006, 11:37 PM   #14 (permalink)
Ken Pisichko
Guest
Posts: n/a
>[/color]
You obviously did not complete grade 9 english. Please explain yourself is a
simpler manner.
> Eat shit, bitch.
>[/color]
My, my, I thought you had a health diet. Now wonder you cannot express yourself
here. You should be sitting on a toilet.
> I am being polite, fuckstain.[/color]
Typical high school "drop out" mentality. Get a real job so that you don't
spend so much time poking at your keyboard... Oh, and get a dictionary for
children. it appears that you need to read one. perhaps a children's level with
a Grade 3 vocabulary will be of benefit to you. Then of course you WILL have
your basic difficulty with understanding what you are reading reading.
As an aside, do you have parents? Perhaps you were left at the side of the road
and raised by uncouth "beings". I could not imagine ANY mother raising an
individual with YOUR attitude. But then, perhaps both parents died at your
birth and thus you were left at the side of the road...
Too bad, but don't take out YOUR frustrations on the other readers. Your
pathetic approach at communication IS funny. Pathetic, but funny. You are just
another lost opportunity for YOUR nation to benefit from another human
being......
Do those" beings" who raised you know what you are doing with THEIR computer?
All the best with your scribbling <giggle>.
Ken.
BB code is Off
Smilies are Off
[IMG] code is Off
5efe head gasket still leaking, I need advice fast !!! reezytercel Tercel, Paseo, Starlet, and Sera Forum 9 05-23-2010 11:26 PM
Timing belt tension spring's purpose AFTER belt install? awmccready Camry & Solara Lounge 4 09-20-2009 02:59 AM
Head gasket? ughhh... inside0ut Pre-88 Toyota Pickup/Hilux 9 02-17-2006 05:40 PM
LS400 Timing belt ryanbls400 General Lexus Discussion 0 02-04-2006 07:41 PM
What seals can I replace with timing belt? Kitto Camry & Solara Lounge 2 01-07-2006 03:38 PM
