Oil Foam - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota USENET Discussion Groups > alt.autos.toyota > alt.autos.toyota.trucks
alt.autos.toyota.trucks Toyota Trucks discussion newsgroup.
Old 03-27-2006, 02:50 PM   #1 (permalink)
Stephen
Guest
Posts: n/a
View Stephen's Photo Gallery
Oil Foam
This may be a stupid questions but I have a smal amount of foam inside
the oil cap on my 2005 Toyota Tundra. Is this normal? The truck is
running great but when I had the oil changed I was told it could be a
problem.
Old 03-27-2006, 05:27 PM   #2 (permalink)
nospam
Guest
Posts: n/a
View nospam's Photo Gallery
Re: Oil Foam
I just looked at the oil cap of my 2005 Tundra and I have the same thing.
I'm taking it to the dealer tomorrow for a fuel pump issue and I'll ask them
about it and post what they tell me.
The fuel pump problem was posted by me on 3/21 and I got the following
response:
Could it be TSB EG043-05 9/28/2005 - Toyota 2003, 2004, 2005 4Runner &
2004, 2005 Highlander and Sienna & 2005 Seqouia, Tacoma and Tundra. Some
customers may experience a "no start" condition and/or M.I.L. "ON" with
DTCs P0300, P0171, and P0174 after the vehicle has cold soaked in
sub-freezing ambient air temperatures. To correct this condition a new
fuel pump sub-tank assembly is now available. Follow the repair procedure
to replace the fuel pump sub-tank assembly."
Also see [url]http://www.lemonlawspecialists.com/tsb/toyota_tundra_2005.html[/url]
rich
"Stephen" <smover@gmail.com> wrote in message
news:1143492632.630175.231850@i40g2000cwc.googlegroups.com...[color=blue]
> problem.
>[/color]
Old 03-27-2006, 06:15 PM   #3 (permalink)
Cyberbilly
Guest
Posts: n/a
View Cyberbilly's Photo Gallery
Re: Oil Foam
> problem.[/color]
Foaming oil is often an indication that antifreeze in leaking into the oil
system; possibly through a bad head gasket. Get it checked.
-CB
Old 03-28-2006, 05:12 PM   #4 (permalink)
nospam
Guest
Posts: n/a
Re: Oil Foam GOOD NEWS!
I spoke to the dealer today and they said their parts manager has a 2005
Tundra also and saw the same foam. He immediately thought "Head Gasket".
They said it's nothing to worry about and it went away after his 3rd oil
change.
I just did my second oil change on my 2005 Tundra, I wiped the foam out of
the cap last night and it hasn't returned yet.
> problem.
>[/color]
Old 03-28-2006, 05:44 PM   #5 (permalink)
W.T. MC GLYNN
Guest
Posts: n/a
View W.T. MC GLYNN's Photo Gallery
Be very sure that the oil was not over filled.This could cause it to
foam.
Good Luck....
Old 03-29-2006, 06:37 AM   #6 (permalink)
Doug Kanter
Guest
Posts: n/a
View Doug Kanter's Photo Gallery
"W.T. MC GLYNN" <JEANJELLYBEAN1@webtv.net> wrote in message
news:6150-4429CA40-1264@storefull-3278.bay.webtv.net...[color=blue]
> foam.
> Good Luck....
>[/color]
Are you suggesting that some mechanics might be confusing quarts with
gallons, especially if they work at those instant oil change places? How
could that be? :-) :-)
Old 04-02-2006, 01:20 AM   #7 (permalink)
rich
Guest
Posts: n/a
View rich's Photo Gallery
On Tue, 28 Mar 2006 23:12:59 +0000, nospam wrote:
[color=blue]
> change.
> news:1143492632.630175.231850@i40g2000cwc.googlegroups.com...[color=green]
>> problem.
>>[/color][/color]
From what I've read the strange oil near the inlet and cap is a common
issue with this engine. Also, from what I've read, it seems to happen
more in the winter, especially if the engine is used frequently for short
trips. I guess water has a tendency to condense there?
[url]http://www.tundrasolutions.com/forums/tundra/59621-help-mung-under-oil-filler-cap/[/url]
Shorter link version [url]http://tinyurl.com/jae45[/url]
rich
Old 04-02-2006, 03:55 PM   #8 (permalink)
davidj92
Guest
Posts: n/a
View davidj92's Photo Gallery
rich wrote:[color=blue]
>[color=green]
>> 2005 Tundra also and saw the same foam. He immediately thought "Head
>> Gasket". They said it's nothing to worry about and it went away
>> after his 3rd oil change.
>> out of the cap last night and it hasn't returned yet.
>> news:1143492632.630175.231850@i40g2000cwc.googlegroups.com...[color=darkred]
>>> inside the oil cap on my 2005 Toyota Tundra. Is this normal? The
>>> truck is running great but when I had the oil changed I was told it
>>> could be a problem.
>>>[/color][/color]
> short trips. I guess water has a tendency to condense there?
> rich[/color]
Actually this foaming around filler cap and crankcase vents is common on
most engines. Usually, unless there is a large amount of foam it's not
indicative of a problem.
Dave
BB code is Off
Smilies are Off
[IMG] code is Off
oil change interval question nomad 2nd Generation (2005+) 15 06-29-2010 09:01 PM
HELP! Ran without oil due to leak Jakelukas Camry & Solara Lounge 4 08-14-2005 12:33 AM
Puddle of oil leaking from where? 97&02camryleI4 Camry & Solara Lounge 13 10-31-2004 12:36 PM
? Bad Oil Pump Gen2 1989 2.0L ? mk3glx 1st & 2nd Generation (1983–1986 & 1987-1991) 1 10-21-2004 10:48 AM
Help!! Oil Puddle Under Engine Structureboy Camry & Solara Lounge 12 01-17-2003 12:04 PM
