Dash lights. 94 4wd pickup - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota USENET Discussion Groups > alt.autos.toyota > alt.autos.toyota.trucks
alt.autos.toyota.trucks Toyota Trucks discussion newsgroup.
Old 03-28-2006, 02:47 PM   #1 (permalink)
Brad
Guest
Posts: n/a
View Brad's Photo Gallery
I recently purchased my 94 4wd toyota pickup. I have a dumb question.
Does the AC control panel light up? If so gues I have another project
to play with.
Old 03-28-2006, 05:51 PM   #2 (permalink)
Scotty
Guest
Posts: n/a
View Scotty's Photo Gallery
Re: Dash lights. 94 4wd pickup
"Brad" <stratmaster@peoplepc.com> wrote in message
news:1143578859.375544.96790@z34g2000cwc.googlegroups.com...[color=blue]
> to play with.
>[/color]
Should do, bulb replacement? Pretty rare for a toyota bulb to blow though
but worth checking out.
Old 03-28-2006, 07:49 PM   #3 (permalink)
Brad
Guest
Posts: n/a
<Should do, bulb replacement? Pretty rare for a toyota bulb to blow
though
<but worth checking out.
So...the control panel does light up?
I have repaired several electrical problems with this truck (reverse
lights, turn signal, windshield wipers, speedometer, knock sensor).
What is one more weekend project. I just wish I would have known that
last weekend when I had the dash out installing a radio. :-}
Old 03-28-2006, 09:59 PM   #4 (permalink)
Tony
Guest
Posts: n/a
View Tony's Photo Gallery
There are two small bulbs back there.. Really easy to change but it may seem
that the power is missing. Did you cut a wire to connect the dimmer to your
radio? This could be the cause...
Tony
Bolts for life!
news:1143596995.796543.90950@e56g2000cwe.googlegroups.com...[color=blue]
> though
>[/color]
Old 03-29-2006, 05:20 AM   #5 (permalink)
Brad
Guest
Posts: n/a
>Did you cut a wire to connect the dimmer to your[color=blue]
>radio? This could be the cause...[/color]
No, I didn't cut any wires. That is a pet peave of mine...never cut
wires or any plug off. I tore the old radio apart and removed the male
plug from it and soldered the wires from the new radio to that.
The lights in the control panel have not worked since I owned the
truck. Do I have to remove the dash again to access the bulbs...or
plug to check for 12v?
R/
Brad
Old 03-29-2006, 07:24 AM   #6 (permalink)
Tony
Guest
Posts: n/a
No you can just remove the A/C panel face. Starting on the side where the
clock goes gently pry it out with a small screw driver. If your radio can be
slid out this may facilitate access from behind to help push it out and get
started. Then there is 3 bolts I believe to release the panel.
Tony
Bolts for life!
news:1143631202.744974.210920@i39g2000cwa.googlegroups.com...[color=blue][color=green]
> R/
> Brad
>[/color]
Old 03-29-2006, 11:25 AM   #7 (permalink)
Brad
Guest
Posts: n/a
Cool, thanks.
Brad
Old 03-29-2006, 11:26 AM   #8 (permalink)
Brad
Guest
Posts: n/a
Cool, thanks.
Brad
Old 03-29-2006, 01:18 PM   #9 (permalink)
vwtopdown
Guest
Posts: n/a
View vwtopdown's Photo Gallery
i just posted this same question a few weeks ago
i have a 94 pickup also. pull the vent sliders off and the face plate.
there is one bulb in there
the faceplate pops off. just be careful
Old 03-30-2006, 04:38 PM   #10 (permalink)
Brad
Guest
Posts: n/a
Thanks for the help. I poped the cover off, removed the light defuser,
and replaced the bulb. It all works now. It even matches my radio
better now. I replaced the green bulb with an orange covered bulb :-}
R/
Brad
Old 03-30-2006, 06:50 PM   #11 (permalink)
Tony
Guest
Posts: n/a
Yuck, Toyota's worst mistake was going back to Orange dash lights...
Tony
Bolts for life!
news:1143758314.600584.78190@u72g2000cwu.googlegroups.com...[color=blue]
> R/
> Brad
>[/color]
BB code is Off
Smilies are Off
[IMG] code is Off
Dash Lights Out Mr Urban 7th Generation (1993-1997) 11 08-29-2010 05:54 PM
Problem with dash lights and DRL shadowninja General Discussion 7 04-30-2005 11:33 PM
No dash lights ? David*All-Trac Archived Corolla threads 2 02-11-2005 01:53 PM
My dash lights went out! xavior66 Camry & Solara Lounge 5 08-03-2004 01:38 AM
