water pump question - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota USENET Discussion Groups > alt.autos.toyota > alt.autos.toyota.trucks
alt.autos.toyota.trucks Toyota Trucks discussion newsgroup.
Old 04-01-2006, 07:41 PM   #1 (permalink)
jperry
Guest
Posts: n/a
View jperry's Photo Gallery
water pump question
I have a 95 4runner, V6 3VZE 3.0, I am doing the head gasket fix, I have it
all apart and I am wondering about the water pump. There is a little bit of
residue on the lower end of the block. I wiped off the area and it doesn't
seem to be coming from the water pump. Should I replace the water pump
while I am there or take it off and check it out? I haven't had any
problems other than the antifreeze in the oil due to the failed gasket. Any
thoughts are appreciated.
Jim
Old 04-02-2006, 10:53 AM   #2 (permalink)
MrFixit469
Guest
Posts: n/a
View MrFixit469's Photo Gallery
Re: water pump question
If you're that far into it, CHANGE IT! It's cheap insurance and will
prevent you from having to go through all that trouble a second time
later.
Old 04-02-2006, 11:45 AM   #3 (permalink)
Tony
Guest
Posts: n/a
View Tony's Photo Gallery
I second that response, besides if the water pump freezes on you then you
will have to replace the timing belt also.. Oh yeah while you are there,
change that also.. Again good insurance...
Tony
Bolts for life!
"MrFixit469" <MrFixit469@verizon.net> wrote in message
news:1143993219.177544.231600@t31g2000cwb.googlegroups.com...[color=blue]
> later.
>[/color]
BB code is Off
Smilies are Off
[IMG] code is Off
water pump location? fidnee Tercel, Paseo, Starlet, and Sera Forum 3 04-24-2005 05:06 PM
water injection question IMPORTMyth01 MR2 Forum 2 11-03-2004 01:57 PM
98 Tacoma water leak question eviljap 1st Generation (1995.5–2004) 3 10-22-2004 04:09 PM
Water Pump TigerSilhouette Archived Corolla threads 4 11-26-2002 12:03 AM
Water Pump TigerSilhouette General Discussion 0 08-23-2002 06:44 PM
