84 22r ps belt tensioner - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota USENET Discussion Groups > alt.autos.toyota > alt.autos.toyota.trucks
alt.autos.toyota.trucks Toyota Trucks discussion newsgroup.
Old 04-04-2006, 05:19 PM   #1 (permalink)
pheasant
Guest
Posts: n/a
View pheasant's Photo Gallery
Old Chevy guy here, used to tightening belts with a cheater bar.
Power steering belt snapped. Is the tensioning screw the one in the
middle of the idler pulley? Is there a nut on the underside, or just a
matter of turning the capscrew until desired tension. Is there a lock nut?
Thanks
Old 04-04-2006, 05:21 PM   #2 (permalink)
pheasant
Guest
Posts: n/a
Re: 84 22r ps belt tensioner
pheasant wrote:[color=blue]
> Thanks[/color]
Not the bolt that holds the pulley to the frame, but the one on top of
the housing is what I meant for the adjusting screw.
Fracka Rakkas!!
Old 04-04-2006, 11:25 PM   #3 (permalink)
Bruce L. Bergman
Guest
Posts: n/a
View Bruce L. Bergman's Photo Gallery
On Tue, 04 Apr 2006 17:19:46 -0500, pheasant <kiavan02@yahoo.com>
wrote:
[color=blue]
>Old Chevy guy here, used to tightening belts with a cheater bar.[/color]
Been there, Done that - still have to on the Corvair, that's the
only way...
[color=blue]
>matter of turning the capscrew until desired tension. Is there a lock nut?[/color]
IIRC on a 22R the bolt in the middle of the pulley releases the
slider block from the bracket, and there's a separate tensioner
jackscrew that moves the whole pulley up and down in the slides to
adjust the tension. Then you lock it back down with the center bolt.
Oh, and either go get a belt tension gauge tool (Krikit) or read up
on belt tensioning. Too tight is much worse than too loose - you
start killing alternator, water-pump, PS Pump and idler bearings.
Whichever one is weakest and/or most expensive and difficult to fix.
--<< Bruce >>--
Bruce L. Bergman, Woodland Hills (Los Angeles) CA - Desktop
Electrician for Westend Electric - CA726700
5737 Kanan Rd. #359, Agoura CA 91301 (818) 889-9545
Spamtrapped address: Remove the python and the invalid, and use a net.
Old 04-04-2006, 11:50 PM   #4 (permalink)
Bill Chaplin
Guest
Posts: n/a
View Bill Chaplin's Photo Gallery
Bolt in center of bearing is lock,cross bolt adjusts.
pheasant wrote:
[color=blue]
> Thanks[/color]
Old 04-05-2006, 05:49 PM   #5 (permalink)
pheasant
Guest
Posts: n/a
Bill Chaplin wrote:[color=blue]
> Bolt in center of bearing is lock,cross bolt adjusts.[/color]
Thanks guys!!
That was LOTS easier than the old cheater bar method. ;)
Mark
The world's least questioned excuse for missing work....
"the voices in my head told me to stay home and clean guns today".
Oooookay...
Old 04-05-2006, 09:03 PM   #6 (permalink)
Bruce L. Bergman
Guest
Posts: n/a
On Wed, 05 Apr 2006 17:49:52 -0500, pheasant <kiavan02@yahoo.com>
wrote:
[color=blue]
>Bill Chaplin wrote:[color=green]
>Thanks guys!!
>Mark[/color]
The Toyota Engineers aren't as think as you dumb they are... Or
something like that...
The GM engineers probably came up with something similar, but the
change was voted down by upper management because it would cost a
whopping 20 or 25 cents more per car built to implement.
And making incremental design improvements like that would increase
overall reliability, which is a bad thing when GM wants to sell people
a new car every three or four years like clockwork - they want to
convince the owners that at 100,000 Miles any car on the road is worn
out, totally unsafe to drive, and ready to scrap.
Cynical? Me???
--<< Bruce >>--
BB code is Off
Smilies are Off
[IMG] code is Off
My Timing Belt Job (Pics) 56k go away Ken4 Camry & Solara Lounge 113 05-18-2011 09:06 AM
Replacing Serpentine Belt and Tensioner mbd Archived Corolla threads 4 08-30-2004 10:07 AM
98 Corolla Belt Tensioner kevinp Archived Corolla threads 1 05-19-2004 04:52 AM
