cam sensor on a 96 v6 - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota USENET Discussion Groups > alt.autos.toyota > alt.autos.toyota.trucks
alt.autos.toyota.trucks Toyota Trucks discussion newsgroup.
Old 04-07-2006, 02:16 PM   #1 (permalink)
Robert
Guest
Posts: n/a
View Robert's Photo Gallery
I have a 96 tacoma with the 3.4l V6. The check engine light just came
on yesterday with a new one for me. Is the cam sensor difficult to
replace, or should I have a shop do it? Any special tools needed? What
is a typical price for the parts needed?
Thanks, Robert
Old 04-09-2006, 09:05 AM   #2 (permalink)
Jeff Strickland
Guest
Posts: n/a
View Jeff Strickland's Photo Gallery
Re: cam sensor on a 96 v6
I don't know the answer to your question, directly. But, the Cam Sensor is
sometimes part of what looks like a distributor. I don't know how they
designed your '96, but I suspect you have a distributor. The Cam Sensor can
be part of what formerly played the role of points -- not exactly "points",
but in the same place.
If I'm correct, the fix is to replace the distributor. This is a relatively
easy project. MAKE SURE the engine is at TDC, then pull the distributor and
drop in a new one. I hate to state the obvious, but be sure the engine is at
TDC, and the new distributor is pointed at the #1 position BEFORE you
attempt to start the motor. Many new distributors will come with a lock pin
in them that holds the rotor on #1, DO NOT remove the pin until after the
distributor is correctly installed.
<Robert> wrote in message news:rfed321j5i968q1k293875ba559lf1qeku@4ax.com...[color=blue]
> Thanks, Robert[/color]
Old 04-11-2006, 01:57 PM   #3 (permalink)
Robert
Guest
Posts: n/a
Thank you for the help, but the 96 has the distributerless ignition.
There are three coil packs. I have also added an MSD add-on ignition,
larger injectors, and the TRD SC (1st gen)
I'm hoping the error code goes along with the bad ground wire a local
shop that specializes in electronics found.
On Sun, 9 Apr 2006 07:05:29 -0700, "Jeff Strickland" <crwlr@yahoo.com>
wrote:
[color=blue]
><Robert> wrote in message news:rfed321j5i968q1k293875ba559lf1qeku@4ax.com...[color=green]
>> Thanks, Robert[/color][/color]
BB code is Off
Smilies are Off
[IMG] code is Off
Very interesting... NH05TACOMA 2nd Generation (2005+) 52 04-08-2008 06:20 PM
thinking bout buying a camry for my next car 96 up 4clyinder or v6 . cool car guy 3rd & 4th Generation (1992–1996 & 1997–2001) 20 04-30-2005 06:59 PM
which magnaflow exhaust for 96 v6 camry robehsi 3rd & 4th Generation (1992–1996 & 1997–2001) 4 04-21-2004 04:59 PM
96 Camry LE V6 vs 98 Camry XLE V6 2001CamryLE 3rd & 4th Generation (1992–1996 & 1997–2001) 7 05-13-2002 07:53 PM
