98 Tacoma starting question - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota USENET Discussion Groups > alt.autos.toyota > alt.autos.toyota.trucks
alt.autos.toyota.trucks Toyota Trucks discussion newsgroup.
Old 04-07-2006, 08:03 PM   #1 (permalink)
Grip
Guest
Posts: n/a
View Grip's Photo Gallery
Hey All, and thanks for reading this post.
Put a brand new battery in my 98 V-6 Tacoma with 140k today. Went to store,
came out and truck would not turn over(never happened before). Lights were
strong, all electronics cool, so battery was not the issue. I'm thinking
perhaps that switch when you depress the clutch? But then I tried it with
the "START WITHOUT CLUTCH" button, still nothing. Finally after 10-15 key
turns, it fires up and I drive home. Tried it several times at home and it's
fine........now I'm thinking a new starter? Ideas anyone? Is a starter hard
to swap in this vehicle?
Thanks again,
Mike
Old 04-07-2006, 08:09 PM   #2 (permalink)
davidj92
Guest
Posts: n/a
View davidj92's Photo Gallery
Re: 98 Tacoma starting question
Grip wrote:[color=blue]
> store, came out and truck would not turn over(never happened before).
> Lights were strong, all electronics cool, so battery was not the
> issue. I'm thinking perhaps that switch when you depress the clutch?
> But then I tried it with the "START WITHOUT CLUTCH" button, still
> nothing. Finally after 10-15 key turns, it fires up and I drive home.
> Tried it several times at home and it's fine........now I'm thinking
> a new starter? Ideas anyone? Is a starter hard to swap in this
> vehicle?
> Thanks again,
> Mike[/color]
A common problem with Toyota starters is the contacts getting burnt/pitted.
Do a google for this, there is a ton of info on how-to and part numbers.
HTH, Dave
Old 04-07-2006, 08:09 PM   #3 (permalink)
Tony
Guest
Posts: n/a
View Tony's Photo Gallery
Try the starter relay... If you had normal indications when you turn the key
then this could be a good place to start. Also when it did turn over if the
starter sounded normal, again not likely the problem.
Good luck
Tony
"Grip" <mbetts@suscom.net> wrote in message
news:f82dnQCA_upQlqrZRVn-ig@suscom.com...[color=blue]
> store,
> it's
> hard
> Thanks again,
> Mike
>[/color]
Old 04-08-2006, 08:46 AM   #4 (permalink)
Mike
Guest
Posts: n/a
View Mike's Photo Gallery
> store,
> it's
> hard
> Thanks again,
> Mike
>[/color]
This link should have the info you need to replace your stater contacts.
[url]http://www.tacomaterritory.com/boophoenix/starter.html[/url]
Old 04-10-2006, 10:10 AM   #5 (permalink)
Grip
Guest
Posts: n/a
Thank guys,
Turned out being contacts, I'm farming out the work as I don't have the
time....
Dealer $180.
SMall shop specializing in Toyotas....$90.
"Mike" <mik@localnet.com> wrote in message
news:9%OZf.5239$kg.3716@news02.roc.ny...[color=blue]
> news:f82dnQCA_upQlqrZRVn-ig@suscom.com...[color=green]
> > store,
> > came out and truck would not turn over(never happened before). Lights[/color][/color]
were[color=blue][color=green]
> > perhaps that switch when you depress the clutch? But then I tried it[/color][/color]
with[color=blue][color=green]
> > the "START WITHOUT CLUTCH" button, still nothing. Finally after 10-15[/color][/color]
key[color=blue][color=green]
> > it's
> > hard
> > Thanks again,
> > Mike
> >[/color]
> This link should have the info you need to replace your stater[/color]
contacts.[color=blue]
>[/color]
BB code is Off
Smilies are Off
[IMG] code is Off
98 Camry 150k Diagnosis and Brake Question tallassazn 3rd & 4th Generation (1992–1996 & 1997–2001) 5 08-07-2006 12:07 AM
Starting Problems 98 corrolla hasher Archived Corolla threads 0 02-08-2005 04:30 PM
98 Tacoma Lurches/Jerks on wet mornings CJB 1st Generation (1995.5–2004) 3 11-28-2004 10:56 AM
03 Tacoma Stange Noise Question. Neo Sharkey 1st Generation (1995.5–2004) 3 02-05-2003 10:39 PM
98 Tacoma Passenger Airbag question a-brooklyn-mile 1st Generation (1995.5–2004) 1 08-24-2002 06:43 PM
