Mystery oil consumption - 2002 Highlander V6 - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota USENET Discussion Groups > alt.autos.toyota > alt.autos.toyota.trucks
alt.autos.toyota.trucks Toyota Trucks discussion newsgroup.
Old 04-15-2006, 06:51 PM   #1 (permalink)
Bud H
Guest
Posts: n/a
View Bud H's Photo Gallery
I have a 2002 Toyota Highlander V6 with 130,000 miles which had exhibited
negligible oil consumption between oil changes -- that is, until about a
month ago.
Just as I was arriving home from work, I saw the low oil pressure light blip
on for a moment. When I checked the oil level, I found almost nothing was
showing on the dipstick!
I refilled it to the full line and have been monitoring it every few days,
checking it first thing in the morning before starting to make it easy to
see the oil on the dipstick.
It is using about 1 quart of oil (Mobil 1 synthetic - I've used synthetic
oil since the 10,000 mile mark) every 5,000 miles now after using nothing
during the first 120,000 miles. There are no visible leaks, and I don't see
anything unusual with the exhaust to show oil consumption.
Any idea where the 1 quart of oil every 5,000 miles is going?
Bud H
Old 04-18-2006, 11:32 PM   #2 (permalink)
zonie
Guest
Posts: n/a
View zonie's Photo Gallery
Re: Mystery oil consumption - 2002 Highlander V6
Bud,
Strange problem. I couldnt imagine what has gone on in your Highlander. I
use Mobil 1 also and have no oil consumption . Please keep us posted on
what you find out. Scott
Old 04-21-2006, 01:05 AM   #3 (permalink)
MrFixit469
Guest
Posts: n/a
View MrFixit469's Photo Gallery
Full synthetic oil IS NOT recommended for high mileage engines such as
yours as the synthetic formulation has a tendancy to seep through seals
& gaskets more than conventional motor oils. I have seen NUMEROUS
vehicles with 75,000 plus miles exibit "mysterious" oil consumption or
annoying leaks while using synthetic oils, just to have the problem
solved by switching back to conventional motor oil and having it
changed as recommended.
Old 04-22-2006, 09:36 AM   #4 (permalink)
ds549@webtv.net
Guest
Posts: n/a
View ds549@webtv.net's Photo Gallery
check pcv valve and filter..
[url]http://www.minibite.com/america/malone.htm[/url]
Old 04-22-2006, 11:49 AM   #5 (permalink)
Ken Shelton
Guest
Posts: n/a
View Ken Shelton's Photo Gallery
MrFixit469 wrote:[color=blue]
>[/color]
Lots of big trucks run their engines over a million miles on
synthetic oil, Mobil Delvac 1 being one of the oils. There
sometimes is a problem starting synthetic oil on high mileage
engines, but that goes away after one to three oil change intervals.
I do not know where the Highlander oil might be going.
Ken
Old 04-23-2006, 11:17 AM   #6 (permalink)
View PeonHonda's Photo Gallery
actually ken, if you switch to synthetic oil after you have been using conventional oil for some time the problem should not go away. in conventional oil the oil molecules are larger than those in synthetic oil. that is why people who switch to synthetic oil after long use of convetional oil are complaing of oil consumption and oil leaks.
PeonHonda is offline   Reply With Quote
BB code is Off
Smilies are Off
[IMG] code is Off
Oil Changes for Dummies Peter Off Topic 20 01-04-2006 05:32 AM
V6 Gen 3 Oil Leak? Stangar 3rd & 4th Generation (1992–1996 & 1997–2001) 14 08-15-2005 05:07 PM
Highlander Hybrid Suv Will Make Canadian Debut In Montreal rolla-XRS Toyota News 4 01-14-2005 01:29 AM
About Oil and Gas for 2005 Camry V6 liuhais 5th & 6th Generation (2002-2006 & 2007-2011) 43 12-03-2004 10:24 PM
Synthetic Oil for the Camry 2002 LE V6 2002Camry 5th & 6th Generation (2002-2006 & 2007-2011) 2 01-26-2002 01:45 AM
