4runner 1994 22RE Mexico - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota USENET Discussion Groups > alt.autos.toyota > alt.autos.toyota.trucks
alt.autos.toyota.trucks Toyota Trucks discussion newsgroup.
Old 04-18-2006, 06:52 PM   #1 (permalink)
jkamberos@hotmail.com
Guest
Posts: n/a
View jkamberos@hotmail.com's Photo Gallery
Hola tengo una 4runner ' 94 con motor 22RE 4L, y aqui es raro tener una
que no sea 6V asi que el que tenga otra digame que le han metido para
mayor torque.
4Runner '94 22RE
31 X 10.50 R15
Arbol de levas Crower
Tubo de escape de 2.5 " sin catalizador
Flow master
Old 04-19-2006, 10:08 AM   #2 (permalink)
Mike Harris
Guest
Posts: n/a
View Mike Harris's Photo Gallery
Re: 4runner 1994 22RE Mexico
<jkamberos@hotmail.com> wrote in message
news:1145400752.289635.49140@j33g2000cwa.googlegroups.com...[color=blue]
> mayor torque.
> 4Runner '94 22RE
> 31 X 10.50 R15
> Flow master[/color]
This is a truck engine and is set up for about as much torque as it can
produce.
If you wanted to spend more money you could get a cylinder head from a 20R,
port it and polish it, and install a different cam. If the truck were mine
I would find a used V6 engine before going through that trouble.
I assume from the year that it's fuel injected. If it has a carburetor,
dual side draft carburetors such as the Weber 38 will work well. Don't
remove fuel injection to put on carburetors.
2.75" exhaust might work better but this would be an expensive modification
for not much difference.
If your power is OK and torque at the wheels is what you want, regear the
differentials.
Mike Harris
Austin, TX
BB code is Off
Smilies are Off
[IMG] code is Off
1991 22re going into 1994 pickup JAYRIS 89-95 Toyota Pickup/Hilux 5 10-05-2005 01:34 PM
88 4runner 22re hard miss on incline 884runner 4Runner Lounge 1 01-23-2005 09:16 PM
86r 4runner 22re egr problems skip scrowley111 4Runner Lounge 1 01-14-2005 01:18 PM
