Ok, I'm reeeeally hoping I can get some good feedback on a problem I'm
having w/ my 92 4runner. The problem is that it shifts extremely hard
between gears, as if there was nothing to smooth the transition between
gears. It's an automatic, V6, 4WD. It's not that it shifts at a high
RPM,
causing the shift to be hard. It shifts hard no matter what RPM it
shifts at. It used to only do this about 10% of the time. Now it's
doing this about 90% of the time. If it's not shifting hard, I cannot
figure out how to make it shift hard. It has nothing to do with the
EFT Power button, the OD button, or temperature of the engine or the
air. It seemed pretty random when it did this only 10% of the time.
I've changed the transmission fluid and filter screen - no improvement.
I'm thinking it could be the torque converter, but I don't know much
about those.
I also notice that when it's cold, it tends to wait until a high RPM
before shifting into second gear. This has gotten progressively worse
as the shifting hard has gotten worse...maybe related?
Any advice would be appreciated. I just hate to dump money into it
until I have a good idea of where the problem likely is.
[email]habersetzer@gmail.com[/email] wrote:[color=blue]
> RPM,
> about those.
> Thanks,
> V[/color]
any advice?
you sure?
ok, here goes.........
It's not broke, but it's braking.
Fix it now, or fix it later.
Fix it now, and you can drive it to the shop.
Wait till later and you may have to tow it.
Fix it now, and it won't be a surprise.
Wait till later, and you may get a surprise while away from home,
on a long road, at night, in a hail storm, or even worse, while
the ole ladies with you and then you'll have to hear all them
"I told you so's".
I'm not sure my reply will be of any help, but I have had a simliar
problem. I have 94 p/u with an auto and a 4-banger and shifted exactly
as your described it. I would start with looking at the vacuum hoses,
vacuum switch valve (vsv), and checking the throttle cables. When I put
back together my engine, some of the hoses were off or were cracked. I
replaced all my vacuum hoses, and cleaned out this filter thing. I
can't remember the name of it, but I'll post when I remember it. For my
truck, adjusting the throttle cable seem to do the trick, it's still a
little rough, but I think I can adjust it some more to get what I want.
Also check the throttle position sensor as described in the
haynes/chilton manuals. Hope that helps you to get started.
Thanks yippie! I appreciate the information. Someone else mentioned
vacuum hoses, but there are so many and I wasn't sure how to check to
see if one is leaking. I've got a question about the throttling cable
- is that related to the shifting hard, or the late shifting from first
to second?
Truthfully, if any of the hoses are cracked, or just hasn't been
replaced at all since it rolled out of the factory, I would go ahead
and replace all of them. I bought 15 bucks worth of hoses at autozone
and replaced all of them in about 30 minutes, replacing 1 at a time.
About the throttle cable, I'm not sure about how it's related to the
shifting, but all I know is that when I adjusted it, the shifting
changed for the better. It could be a sticking throttle cable too. Here
are some links similar.
Also one more thing too, while changing out those vacuum hoses, I would
blow some compressed air or something like that to see if it clogged
anywhere. I blew some through my throttle body and some dust stuff came
out. It's not necessary to do this, but if you have the time and a
compressed air source, certainly easy to do when all that stuff is off.
Hope it'll get your toy back to normal.
Oh and that one part that you might want to check and clean is called
the EGR vacuum modulator, or EGR modulator. Have to open it up some and
check the filter element in it. It could be clogged. I think the manual
just recommends to blow some air in it, but this is for a 22re, not
sure about the 3.0 v6.
great advice. I remember reading about the EGR modulator on
autozone.com. they have a pretty good troubleshooting section online.
I'm going to try to tackle this over the weekend.
I noticed today that the hard shifting seems to go away when the engine
is warmed up. Not sure if that's a consistent behavior, so I'll pay
attention over the next few days to see if that's the pattern. If it's
related to engine temp, would that give any clues as to the problem?
I'm not sure, but I think most cars tend to shift a little rough before
everything is warmed up. Mine certainly does that being a 94. My guess
would be either vacuum leak, or a sensor going down. As far as the
sensors, I'm looking into what may affect the transmission. Could be a
solenoid problem. I'll let you know what I find.
Hey, thanks for the help! Do you know if sensors are located outside
the transmission where I could potentially get to them to replace them?
I hate to think that I'll have to have the transmission removed /
rebuilt, so anything outside the transmission that could cause the
shifting problem is definitely worth looking into. I'm not sure how to
tell if a sensor is bad. I can read up on that.
