My 1996 Tacoma (94k, V6, ext. cab, LX, 2 wheel drive) seems to vibrate
excessively (truck and steering wheel) at exactly 65mph. On city roads it is
not noticeable and at about 75mph it does not really seem that bad. The
tires were replaced about eighteen months ago and have about 10k miles on
them with very little but even wear.
What should I have checked out when I take it into the shop??
On Sun, 23 Apr 2006 15:33:34 -0700, "marspinball"
<martinhirschREMOVEtheSPAM@cox.net> wrote:
[color=blue]
>Hi
>Thanks, Martin
>[/color]
Front tire balance for starters and if it good, check for broken belts
in tires (tire will be out of round)
The SnoMan
[url]www.thesnoman.com[/url]
If you have larger tires, they may vibrate. Even if they are balanced etc,
larger tires are harder to get a perfect balance on install. I have 31s on
my truck and around 100kph (60mph) they vibrate slightly. At 110kph, its not
as bad. I guess there's a frequency at 100kph that makes it worse. But where
I have balancing sand in my tires, the vibration subsides as the sand
balances the tire.
"SnoMan" <admin@snoman.com> wrote in message
news:i97o4295v8pek1qim2sci5ojbbr6k1fr2j@4ax.com...[color=blue]
>[color=green]
> >Hi
> >excessively (truck and steering wheel) at exactly 65mph. On city roads it[/color][/color]
is[color=blue][color=green]
> >Thanks, Martin
> >[/color]
> The SnoMan
> [url]www.thesnoman.com[/url][/color]
I had a similiar problem with my '98 taco 4x4. Occasionally at 70 mph
it would start vibrating and get quite violent, I would have to slow
the vehicle almost to a stop to alleviate the vibrations. Tire balance
and allignment did nothing. Tire rotation solved the problem, hasn't
happened since (over a year).
On 24 Apr 2006 05:04:57 -0700, "mDunbar" <matthew.dunbar@gmail.com>
wrote:
[color=blue]
>Martin,
>Matt[/color]
You have a tire out of round or a broken belt. I had a 91 Camary that
I used to use Firestone "T" rated tires on it because I liked the
handling and traction but after about 35 or 40K I would have problems
with belts in tires breaking and one of more tires going out of round
and causing problem. Firestone was could about replacing them with a
fair adjustment in price for a new set of 4 so I continued to use them
for over 150K miles.
The SnoMan
This happened to me with a 4runner. As it turns out, 4runner and at
tacoma (at least some tacoma) have 'lug-centric' wheels. This means
that any balancing has to be done with the wheel centering based on the
lugs, not the hub. To balance a lug-centric wheel, the wheel has to be
mounted on a jig, then the wheel/jig assembly balanced in a standard
hub-centric balancer. One such jig is made by Haweka. Also, look for a
shop with a Hunter GSP-9700 Road Force Balancer
Sorry Brad, but large tires can be balanced if done properly, and they can
be balanced to .09 grams, anything under 19 grams is not noticable, (not
transferred to hub center)
Check your driveshaft and make sure all is tight where it connects at the
knuckles. I had a similar problem that balancing and alignment would not
take care of and turned out to be one of the knuckles was very loose causing
it to shake.
Good luck,
Scott..
"marspinball" <martinhirschREMOVEtheSPAM@cox.net> wrote in message
news:YgT2g.5360$Jk2.3736@fed1read03...[color=blue]
> Hi
> is not noticeable and at about 75mph it does not really seem that bad. The
> Thanks, Martin
>[/color]
