Re: broken spark plug
"heferunner" <allorfloors@carolina.rr.com> wrote in message
news:1146533887.121115.6480@g10g2000cwb.googlegroups.com...[color=blue]
> Anyone have any help? I was changing the sparkplugs on a 1988 4 Runner
> I just purchased, and the bolt and the end of the spark plug broke off
> leaving the threaded end of the sparkplug in the head. I have put an
> e-z out into the broken off section of the sparkplug, but now I have
> the e-z out and the remainder of the spark plug stuck in the head. I
> have tried to weld a nut onto the end of the e-z out in order to remove
> it, but the nut keeps stripping and spinning. I realize if I can just
> remove the (easy fix) e-z out from the inside of the plug, I can
> probably drill out the plug. Any suggestions. Desperate!!!!
>[/color]
If the ez out is not broken off you should be able to remove it by turnig
it backwards. To keep from breaking off the ez out in the spark plug threads
use the largest size ez out that will fit. Another option, as you suggested,
is to drill out the remainder of the old spark plug. If you ruin the threads
in the cylinder head you can repair them using a helicoil insert. You should
be able to find a spark plug thread repair kit at most auto parts stores. It
should contain everything you need to repair one spark plug hole. If you go
with the helicoil repair you need to drill out the old spark plug hole
anyway so that may be a better choice from the start.
