Re: U Joint lube
Ray wrote:[color=blue]
> What type of Grease do you use on the Universal Joints .[/color]
I like a top-quality moly grease, but not the 5% moly heavy duty
grease used by front end loader pins, etc.
The moly grease is required in the double cardan joint that looks
like two u-joints together. The base is usually lithium or lithium
complex, although I use an aluminum complex base moly grease which
is compatible with the lithium base greases and is more waterproof.
The oil in the grease can be either synthetic or conventional.
(Grease is a mixture of a base (thickener), oil, and additives like
moly, graphite, teflon (OK in grease, no-no in engine oil), dye).
Ken
