Clutch problem, slave or master cylinder? - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota USENET Discussion Groups > alt.autos.toyota > alt.autos.toyota.trucks
alt.autos.toyota.trucks Toyota Trucks discussion newsgroup.
Old 05-08-2006, 02:33 PM   #1 (permalink)
Monkey Boy
Guest
Posts: n/a
View Monkey  Boy's Photo Gallery
For about a month now, ive been having problems when pushing the
clutch in. Sometimes it would get "stuck" and not come back up when I
release it. Ive never worked on a clutch system before, but from what
ive read it could be the slave and/or master cylinder.
I would like to hear from other Tacoma owners to see what they think
it is. Any ideas?
If it is the Slave or Master cylinder, should i just replace both
anyway? Any particular brand? AJUSA.COM carrys ASCO/Aisin and PBR.
ASCO/Aisin is about 25% more in price.
1996 Toyota Tacoma Ext Cab
98k miles
Old 05-08-2006, 10:19 PM   #2 (permalink)
Tony
Guest
Posts: n/a
View Tony's Photo Gallery
Re: Clutch problem, slave or master cylinder?
Have you checked you fluid lately, changed it? When it sticks does it pop
back out or does it release slowly? If it pops back out then spray the
inside spring with some white lithium grease. Otherwise it is definitely the
master cylinder. If the slave cylinder was sticking the pedal would come up
but the clutch would slip.
Tony
95 Toyota Tacoma 2wd
"Monkey Boy" <monkeyboy311@gmail.com> wrote in message
news:1147113197.703325.290970@i40g2000cwc.googlegroups.com...[color=blue]
> it is. Any ideas?
> 98k miles
>[/color]
Old 06-11-2006, 08:43 PM   #3 (permalink)
Terry
Guest
Posts: n/a
View Terry's Photo Gallery
I know a Chevy is not a Taco but I just had the same problem and it was
actually the tiniest pinhole you can imagine in the hydraulic line. Good
Luck.
Terry
"Tony" <ac!ark_10@verizon.n@t> wrote in message
news:V_S7g.8839$W83.6597@trnddc07...[color=blue]
> the master cylinder. If the slave cylinder was sticking the pedal would
> come up but the clutch would slip.
> Tony
> news:1147113197.703325.290970@i40g2000cwc.googlegroups.com...[color=green]
>> it is. Any ideas?
>> 98k miles
>>[/color]
>[/color]
BB code is Off
Smilies are Off
[IMG] code is Off
OBDII codes Phi Hardcore Tech and Competition 12 12-24-2011 10:38 AM
4th cylinder misfiring problem fractal Camry & Solara Lounge 5 06-07-2005 06:14 PM
'04 Corolla S ... clutch problem ? NeatO Archived Corolla threads 2 04-12-2005 07:52 PM
clutch or transmission problem ? Ratko Hardcore Tech and Competition 12 01-15-2003 07:27 PM
Need help changing clutch cylinder... foob Archived Corolla threads 0 06-06-2002 07:18 PM
