Squeaking Clutch - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota USENET Discussion Groups > alt.autos.toyota > alt.autos.toyota.trucks
alt.autos.toyota.trucks Toyota Trucks discussion newsgroup.
Old 05-09-2006, 12:04 PM   #1 (permalink)
grinder
Guest
Posts: n/a
View grinder's Photo Gallery
Squeaking Clutch
I have a '90 4runner. Every once in a while the clutch squeaks like a
banshee when depressed. I had one shop tell me it was the result of a
plastic bushing gone bad. I don't necessarily think so because the squeak
seems to be coming from somewhere underneath the car and that year does not
have the same bushing assembly as later models.
I had another shop said it was normal and could not be fixed. I don't think
that is right either.
I also greased all the joints in the cab to no avail.
I also noticed it squeaks most after I take it to the car wash.
Any ideas?
Old 05-09-2006, 12:47 PM   #2 (permalink)
Andy Hill
Guest
Posts: n/a
View Andy Hill's Photo Gallery
Re: Squeaking Clutch
"grinder" <seagle@earthlink.invalid> wrote:[color=blue]
>Any ideas?
>[/color]
Well, sounds like the external linkage needs some grease. If you don't know
what goes where, then buy a friend a beer and have him work the clutch pedal
while you go squeak hunting under the rig with a can of lithium grease.
Old 05-09-2006, 01:10 PM   #3 (permalink)
Mike Harris
Guest
Posts: n/a
View Mike Harris's Photo Gallery
"grinder" <seagle@earthlink.invalid> wrote in message
news:5438g.532$y4.134@newsread2.news.pas.earthlink.net...
[color=blue]
> think that is right either.
> Any ideas?[/color]
I'm assuming that you mean a squeaking noise as you mash the pedal; it would
occur whether the engine was running or not.
That one was addressed by Toyota's TSB TC005-99. It actually calls for
replacing the bracket. The TSB lists the part number for the replacement
pedal brackets for either 4 or 6 cyl that will cure the problem. The TSB
also specifically states not to grease or lubricate the bracket.
If it's a squealing noise that occurs as you mash the pedal, that only
happens when the engine is running, you probably have a throwout bearing on
its way out. If this is the case you may want to live with it if it's an
occasional happening. It's not worth going in unless it's very bad or you
have some other compelling reason to replace your clutch.
Old 05-10-2006, 04:11 PM   #4 (permalink)
grinder
Guest
Posts: n/a
"Mike Harris" <harrisremovethiswest@sbcglobal.net> wrote in message
news:h248g.74369$H71.10828@newssvr13.news.prodigy.com...[color=blue]
>[color=green]
>>not have the same bushing assembly as later models.
>> Any ideas?[/color]
> would occur whether the engine was running or not.
> on its way out. If this is the case you may want to live with it if it's
> an occasional happening. It's not worth going in unless it's very bad or
> you have some other compelling reason to replace your clutch.
>[/color]
Happens regardless if the engine is running. I still think it is odd that
it only seems to happen or happens worse right after it is washed. In any
case at this point in its life I will run it until it breaks.
Old 05-10-2006, 04:44 PM   #5 (permalink)
Mike Harris
Guest
Posts: n/a
Well, if it really gets bad try going under with a spray can of lithium
grease in the manner suggested by Andy Hill. It may not permanently fix the
problem but it might at least buy you a few months of silence.
Mike Harris
Austin, TX
news:jOr8g.1055$Jf.874@newsread4.news.pas.earthlink.net...[color=blue]
> news:h248g.74369$H71.10828@newssvr13.news.prodigy.com...[color=green]
>>[color=darkred]
>>>squeak seems to be coming from somewhere underneath the car and that year
>>>does not have the same bushing assembly as later models.
>>> Any ideas?[/color]
>>[/color]
>[/color]
Old 05-11-2006, 10:40 AM   #6 (permalink)
grinder
Guest
Posts: n/a
news:Egs8g.68918$_S7.31331@newssvr14.news.prodigy.com...[color=blue]
> the problem but it might at least buy you a few months of silence.
> Mike Harris
> Austin, TX
>[/color]
It is not consistent. It goes away for a while and then returns. But I
will try to locate the assembly under the car and hit it a few times with
some grease.
BB code is Off
Smilies are Off
[IMG] code is Off
interesting article about double clutching boroEF Hardcore Tech and Competition 40 07-23-2007 02:12 AM
Clutch problem, seeking help. blueapple Celica Forum 0 01-21-2006 01:17 AM
UPDATE: Clutch problem canadianae92 Archived Corolla threads 2 10-29-2005 06:13 PM
My clutch has started slipping and I dont know why REAPER STRAIN Camry & Solara Lounge 55 09-19-2005 08:47 AM
