Re: Resetting computer on Tundra after battery change
Jeff Strickland wrote:[color=blue]
>The computer (engine management) should reset itself after running for
>several minutes. Go ahead and drive around the block. Don't do any wierd
>stuff like rev the motor, just drive normally. The computer should detect
>what is what and where it is, and set itself. The motor should run mormally
>after that.
>[color=green]
>> After I changed the battery, I must have connected the battery cable in
>> the
>> wrong sequence. Now the truck starts, runs for a little bit then dies, it
>> starts right back up[/color][/color]
I'll try again, see what happens, thanks for the help, Jeff.
Ray
