'97 T-100 brake rotor upgrade suggestions?? - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota USENET Discussion Groups > alt.autos.toyota > alt.autos.toyota.trucks
alt.autos.toyota.trucks Toyota Trucks discussion newsgroup.
Old 05-16-2006, 10:01 PM   #1 (permalink)
View xsacta's Photo Gallery
Hello all,
My current rotors have been cut once and are warped. This time I'd like to upgrade. Maybe slotted and/or drilled. Any suggestions? A particular brand? While I wouldn't mind rotors that afforded better braking, I'm more concerned with one's that might last longer where warpage is concerned. TIA!
xsacta is offline   Reply With Quote
Old 05-20-2006, 08:46 AM   #2 (permalink)
Ken Shelton
Guest
Posts: n/a
View Ken Shelton's Photo Gallery
Re: '97 T-100 brake rotor upgrade suggestions??
xsacta wrote:[color=blue]
> Hello all,
> concerned. TIA!
>[/color]
Are they actually warped? Were they measured on the car with a dial
indicator, and was the runout greater than the acceptable
seven-thousandths?
A more common cause of the brake judder you felt is due to the brake
pad material getting hotter than the material was made to handle.
This causes uneven deposits of pad material on the rotors and the
subsequent grabbing. The assumption is made that the rotors are
warped, the rotors are turned removing the buildup of material and
some metal, and they are smooth again for a while.
Any good brand of rotor is likely OK. Wagner, Raybestos, Brembo,
Toyota. I prefer slotted rotors over drilled. Too often drilled
rotors develop cracks at the holes. Racers are now using slotted
rotors. I have SP Performance slotted rotors and Performance
Friction pads (also available under the AutoZone brand) and like
them a lot.
[url]http://www.raceshopper.com/brake_problems.shtml[/url]
Always flush and renew the brake fluid, and every two years is best.
The fluid absorbs moisture from the atmosphere which lowers the
boiling point. The heat from very heavy braking can cause the fluid
to flash to vapor, your pedal goes to the floor, and if you don't
crash you need to change your shorts.
Ken
BB code is Off
Smilies are Off
[IMG] code is Off
GS Brake Problem- Any suggestions? fish General Lexus Discussion 1 02-26-2004 10:08 PM
96 Previa Brake Light Problem dreamakr20 Previa Forum 8 08-09-2003 01:29 AM
Need some suggestions for my brake problem... 24valvage Camry & Solara Lounge 3 01-04-2003 07:11 PM
97 camry LE exterior mods: Suggestions pLZ iLL_WiLL 3rd & 4th Generation (1992–1996 & 1997–2001) 13 09-19-2002 07:03 AM
Brake Pad suggestions.... Phi General Discussion 13 11-24-2001 12:56 PM
