Re: 2003 4runner door locks
hey John,
check your manual..they should have an area where you can change the settings
on your entry system through your remote..If your batery hasnt been changed
in your remote..I suggest you do that first ....then go to that section in
the manual & follow the steps to disengage such settings...I had a 98 4runner
that i did that to
mine would lock the doors when I put it in gear ( I dont like that) so I
reprogrammed it to not do it ~~ Toyota enginners are VERY smart you can do
just about anything you want with them... Hope this helps
Rod
santas little helper wrote:[color=blue]
>My driver side door lock just started to stay locked when the engine
>is off and the key is removed. Is there a code to use with the remote
>to change this?
>John[/color]
Message posted via [url]http://www.carkb.com[/url]
