Toyota oil gauge stopped working and oil still flowing - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota USENET Discussion Groups > alt.autos.toyota > alt.autos.toyota.trucks
alt.autos.toyota.trucks Toyota Trucks discussion newsgroup.
Old 05-22-2006, 11:11 PM   #1 (permalink)
South4t via CarKB.com
Guest
Posts: n/a
View South4t via CarKB.com's Photo Gallery
My '90 toyota pickup oil pressure dial has stopped working after I changed
the oil and filter. I only drove it a few miles when I noticed it was not
working. Truck has 193K miles and new oil seal was put in 3 months ago.
I waited until the next morning so all the oil would be settled in the pan.
With the oil cap off I started the truck so I could see if the oil would pump
from the pan to the rockers. As a result I did see the oil pumping by and
spitting out the cap hole. With that, I the possible problems are:
1) Brand new oil filter was clogged from mfgr - Probably not, oil is flowing
2) Oil pump bad - Probably not, I see oil flowing
3) Oil sensor bad - Seems most likely, need to check wiring first (6)
4) Blown fuse for instraments - Checked fuse panel and nothing was blown
5) Oil Pressure gauge is bad - Might be, but, need to troubleshoot sensor
first
6)Oil sensor wiring came loose -
Can anyone tell me where the sensor is mounted or where I can check wiring?
Thanks, Bill
Message posted via [url]http://www.carkb.com[/url]
Old 05-22-2006, 11:18 PM   #2 (permalink)
Shopdog
Guest
Posts: n/a
View Shopdog's Photo Gallery
Re: Toyota oil gauge stopped working and oil still flowing
Mine did the same thing, also right after the oil change. I haven't done any
checking yet, other than to verify oil IS still flowing. I am under the
impression that the sending unit is bad. I had this problem in my 91 and it
to was the sending unit. My current Toy is a 90 4 Runner 3VZE
Searcher
Make sure oil is flowing
Old 05-23-2006, 08:47 AM   #3 (permalink)
Skip
Guest
Posts: n/a
View Skip's Photo Gallery
On Tue, 23 May 2006 04:11:43 GMT, "South4t via CarKB.com" <u19472@uwe>
wrote:
[color=blue]
>first
>Thanks, Bill[/color]
In my old '89, the oil sending unit was above and a little back from
the oil filter.
Skip
Old 05-23-2006, 09:55 PM   #4 (permalink)
Guest
Posts: n/a
Skip wrote:[color=blue][color=green]
>>the oil and filter. I only drove it a few miles when I noticed it was not[/color]
>[quoted text clipped - 16 lines][color=green]
>the oil filter.
>Skip[/color]
OK all,
I figured it out. I was a wire that disconnected itself when i changed the
oil filter. I just had the truck in the shop where I was rapped and they did
not connect it correctly. The oil pressure sending unit is a round device
that is connected to the block and is directly below the oil filter. There is
also a wiring harness in the area that has the female connector. So, just
connect the two and your oil gauge is back in business.
Laters, Bill
Old 05-24-2006, 05:46 AM   #5 (permalink)
Shopdog
Guest
Posts: n/a
I'm out to check mine now, I'll let you all know shortly.
Searcher
Old 05-24-2006, 05:51 AM   #6 (permalink)
Shopdog
Guest
Posts: n/a
Well, whaddaya know, I got a broken wire. Now I got a project for the day.
Thanks S4t
Searcher
BB code is Off
Smilies are Off
[IMG] code is Off
How to Turbo the Camry - 5s-fTe tips and information Hamsterman Camry & Solara Lounge 118 09-23-2010 10:43 AM
TOYOTA ENGINES AND OIL SLUDGE - WALL ST JOURNAL bondobondo General Discussion 99 02-02-2007 06:54 PM
