Re: Clutch Cylinder Rot
On Tue, 23 May 2006 09:52:33 -0700, Ken Shelton
<shelton@cablespeed.com> wrote:
[color=blue]
>tbl wrote:[color=green]
>> So why do the cylinders in my 1988 Toyota pickup rot out
>> about every 4 years, when the brake cylinders go for 10+?
>> Anybody?[/color]
>Rot?[/color]
Corrosion-pitting causing the piston seals to not seal.
[color=blue]
>Are you getting new or quality rebuilds, or rebuilds that aren't so
>good? I know, it can be hard to tell until it fails too soon.[/color]
Up until yesterday, I've used only Toyota stuff from Toyota
dealer (expensive!).
[color=blue]
>Be sure to replace the brake and clutch fluid every two years. It
>absorbs moisture, and the moisture can cause deterioration as well
>as braking failure during very hot emergency braking.[/color]
I'm sure that the first failure was after about 5 years with
no fluid changes. Surprisingly, it was the master that went
first.
But since then, I've changed fluids every two years, + or -
a few months. The reservoir cap seems to have a breather.
Wouldn't this cause the fluid to "wet" pretty quickly? I
think I'll start changing it every year.
Thanks for the reply.
tbl
