Shifting questions - 1990 4x4 - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota USENET Discussion Groups > alt.autos.toyota > alt.autos.toyota.trucks
alt.autos.toyota.trucks Toyota Trucks discussion newsgroup.
Old 05-27-2006, 11:06 AM   #1 (permalink)
davemcc@shaw.ca
Guest
Posts: n/a
View davemcc@shaw.ca's Photo Gallery
To the experienced, this will seem a bit odd, but I'm a bit new to the
4x4 thing and I've been given conflicting information about this so I'm
looking for experienced advice..... ;-)
I have a 1990 Toyota truck 4x4 5-speed 22RE engine.
Can I shift into LOW (4-wheel) range and drive the truck without
locking the front hubs without doing any damage? This might be when I
want the very slow speed but don't need the actual drive from the front
wheels. I know I won't be in actual 4-wheel drive, but what I want is
the low speed that LOW range gives me.
Also, do I need to take the hubs off LOCK if I shift out of 4-wheel
drive in the cab, if it's just for a short distance?
I guess the question is if you shift into 4-wheel drive do you always
have to trot outside and lock the hubs and vice-versa? Is there a
potential for drive-train damage here if you do the wrong thing?
Dave
Old 05-27-2006, 02:00 PM   #2 (permalink)
DruG
Guest
Posts: n/a
View DruG's Photo Gallery
Re: Shifting questions - 1990 4x4
I know you can shift out of 4 and leave the hubs locked for short distances.
All it does is spin the front drive train resulting in a bit more wear over
time.
-Dru
<davemcc@shaw.ca> wrote in message
news:1148745992.118311.162230@i40g2000cwc.googlegroups.com...[color=blue]
> Dave
>[/color]
Old 05-27-2006, 06:29 PM   #3 (permalink)
Mike
Guest
Posts: n/a
View Mike's Photo Gallery
> the low speed that LOW range gives me.[/color]
Yes, you can use 4 low without the hubs locked. In effect, this gives you
2 wheel low. I use it for the reasons you stated above.
[color=blue]
> drive in the cab, if it's just for a short distance?[/color]
You could keep the hubs locked all the time if you wanted. In fact the
owners manual says you should lock them in once a month to keep the front
axle parts lubed. Unlocking the hubs when in 2 wheel drive gives slightly
better gas mileage and saves wear on you front axle and driveshaft.
[color=blue]
> have to trot outside and lock the hubs and vice-versa?[/color]
If you know you will need 4 wheel drive you can lock the hubs in advance
and just shift the transfer case when 4 wheel drive is needed. As an
example, I live in the northeast. When winter time comes I will lock my hubs
in and when I need 4 wheel drive I just need to shift the transfer case
whithout getting out of the truck, when 4 wheel drive is not needed I just
shift the transfer case back to 2 wheel drive and keep the hubs locked. I
sometimes leave the hubs locked in for months.
Is there a[color=blue]
> potential for drive-train damage here if you do the wrong thing?[/color]
Yes there is. You do not want to use 4 wheel drive on a hard surface, such
as a paved road. When you shift the transfer case into 4 wheel drive the
transfer case locks the front and rear driveshafts together so that the the
front and rear wheels turn at the same speed. When you drive the truck and
make a turn all, 4 wheels turn at a slightly different speed, but 4 wheel
drive won't allow this because the front and rear wheels are forced to turn
at the same speed because they are locked together. This causes the
drivetrain to bind up. When you drive on a slippery surface such as mud,
snow, gravel, dirt, etc... the wheels will be able to spin, which will
allow them to turn at different speeds and does not cause the drivetrain to
bind up.
[color=blue]
> Dave
>[/color]
Old 05-27-2006, 11:21 PM   #4 (permalink)
Jeff Strickland
Guest
Posts: n/a
View Jeff Strickland's Photo Gallery
IF (and I think it is true) that your truck has manual hubs -- where you
have to get out and physically turn a dial to lock the hubs to the axle --
then you are correct, you can select 4LO and have 2WD in LO range.
Obviously, the rear tires will be driving your truck.
No, you do not need to get out and unlock the front hubs after shifting out
of 4WD. The front tires will be turning the front drive train, and this will
consume extra fuel and create added gear wear in the differentials, but I've
had my front hubs locked in 2WD for a very long time.
> Dave
>[/color]
Old 05-27-2006, 11:23 PM   #5 (permalink)
Jeff Strickland
Guest
Posts: n/a
What Mike said.
Old 05-28-2006, 12:03 AM   #6 (permalink)
Scotty
Guest
Posts: n/a
View Scotty's Photo Gallery
> Dave
>[/color]
I used to do it all the time, lauching the boat etc low speeds on the wet
ramp was great.
Never had any issues and no real wear issues resulted.
Old 05-31-2006, 01:37 PM   #7 (permalink)
David
Guest
Posts: n/a
View David's Photo Gallery
[email]davemcc@shaw.ca[/email] wrote:[color=blue]
> Dave
>[/color]
I can think of two minor issues when driving in "L2".
AFAIK there is no kind of automatic synchronization (synchromesh)
between the front axle and the output of the low-gearbox. This means
that if the car is put in H4 while it is moving, a rotating axle meet a
stationary axle.. So if the front hubs are not locked, you should only
change to H4 when the car is at stand-still.
Of course, when the hubs are locked, the rotation of the front and rear
axles will always be directly or indirectly synchronized, which is why
the H2<->H4 transition can be made at any (practical) speed.
The other point is a bit more subtle: When in L4 you have an additional
2:1 gear - this halves the speed-of-revolution, but doubles the torque.
This is not a problem when the front hubs are locked in, as the doubled
torque is distributed across two set of axles. Of course, when the front
hubs are not locked, in the rear axle experiences the doubled torque. I
don't know for a fact if this is a problem, but I would be careful when
driving in "L2" (i.e. no off-roading or trailer-pulling).
However, this is all theoretical and I may be wrong ;).
David
Old 05-31-2006, 08:27 PM   #8 (permalink)
Jeff Strickland
Guest
Posts: n/a
"David" <someone@from.dk> wrote in message
news:447de2a8$0$60781$157c6196@dreader1.cybercity.dk...[color=blue]
> [email]davemcc@shaw.ca[/email] wrote:[color=green]
>> Dave
>>[/color]
> AFAIK there is no kind of automatic synchronization (synchromesh) between
> the front axle and the output of the low-gearbox. This means that if the
> car is put in H4 while it is moving, a rotating axle meet a stationary
> axle.. So if the front hubs are not locked, you should only change to H4
> axles will always be directly or indirectly synchronized, which is why the
>[/color]
The gear ratio in LO Range is the same whether the front hubs are locked or
not. There is no problem at all, if one wants lo speed, high torque, and 2WD
with only the rear wheels getting power.
My Jeep has the ability to engage 2LO in FWD only, the OP wants his 2LO to
be RWD. No problem at all. Offroading and trailer pulling is the most common
time when 2LO will be desired. No problem.
BB code is Off
Smilies are Off
[IMG] code is Off
1990 Toyota Pickup Buyers Guide Questions DaGGer 89-95 Toyota Pickup/Hilux 3 01-05-2006 03:52 PM
Acquired 1990 Pickup. Some Questions... BLAZETIGER 89-95 Toyota Pickup/Hilux 3 11-18-2005 09:07 PM
1990 Corolla SR5 Questions! burnt03 Archived Corolla threads 11 08-09-2005 07:05 AM
1990 SR5 questions 1500cc Archived Corolla threads 2 06-07-2004 04:52 PM
