Re: 1983 toyota pickup
OK... first off it isn't the easiest thing to do... The fact that you are
wondering how the fuel would get to the motor leads me to believe that you
do not have the mechanical prowess to undertake a project like this.. No
offense, just trying to let you know that before hand so you don't get in
the middle of a project that never gets finished, and doesn't cost you an
arm and a leg to have finished..
EVERYTHING that involves the motor from the 4Runner will have to be swapped
into the pickup including but not limited to Motor, and all external
components of the motor such as intake manifold, exhaust manifold,
injectors, all the obvious stuff.. Is the 4Runner a 22re or the 3.0? Since
they didn't make the 3.0 back in 1983, the motor mounts may be different,
but I'm not sure since I've never played with a 3.0.. The whole fuel system
on a fuel injected motor is high pressure, so in order to swap it over..
you'll need to swap the gas tank, fuel pump, and all gas lines from the
4Runner to the pickup.. The Fuel lines in the pickup now are meant for a low
pressure fuel system 5-7psi and cannot handle the pressure from a fuel
injected setup.. The ECM will have to be swapped, and the entire wiring
harness including all sensors.. ie Oxygen sensors, MAF, TPS, all vacuum
lines, and the harness will need to be spliced into the existing truck
wiring.. This is not an extremely easy Project.. I've done many swaps,
Currently in process of swapping a 4.3L Vortec into my 86' truck.. and if I
were you, I'd throw another carburated 22r in.. it would save you from many
headaches, and everything is already there for that motor.. If power is your
problem, then use a little money and make it breath, header, Carb and
intake.. Hope this helps..
Ian
"mad7777777" <marcel_duke@nospam.sympatico.ca> wrote in message
news:ffc5de10ee31bfc2067430d507c1976e@localhost.talkaboutautos.com...[color=blue]
> I know that the Ecm's are eng specific. That's why I am keeping the ecm
> with its original eng. However, I want to take that whole set up and
> install it in my 1983 pickup. Just wondered if maybe there was someone out
> there that could be a little helpful with a little direction as to what I
> might be getting into. I am going to do the swap regardless. The 4runner
> has to come off the road. take to much money to make it safe for the road.
> again, Thank-you.
>[/color]
