22RE RV Cam adjustments - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota USENET Discussion Groups > alt.autos.toyota > alt.autos.toyota.trucks
alt.autos.toyota.trucks Toyota Trucks discussion newsgroup.
Old 06-04-2006, 05:49 AM   #1 (permalink)
Ernie Leimkuhler
Guest
Posts: n/a
View Ernie Leimkuhler's Photo Gallery
I just installed an RV cam in my 86 toyota pickup, 22RE, carbureted.
I am not getting any boost in power.
Is there some trick to adjusting the carb, timing, or valve gaps?
I installed a new head, and entire front end.
Timing Chain, Oil Pump, Water pump Timing Chain Cover.
I gapped the valves to the standard 0.008" intake and 0.012" exhaust.
Set the timing to 0 deg TPD.
I then regapped them after 2 weeks.
Standard NGK Plugs.
I am not trying to make a wall crawler, I just thought I should notice a
difference.
The engine runs smooth and does it's job.
This is a 2WD hybrid truck.
It has the entire rear end from a 86 4WD Toyota, so I have 6 bolt rears
and 5 bolt fronts.
Welding Instructor - South Seattle Comm. Coll.
- Divers Institute of Technology
CWI/CWE
WABO Examiner
Old 06-04-2006, 08:56 AM   #2 (permalink)
mad7777777
Guest
Posts: n/a
View mad7777777's Photo Gallery
Re: 22RE RV Cam adjustments
What did you use for a new chain? Did it have two different sets of marks?
You may have to advance your timing a little. How big of difference is in
both cams?
Old 06-04-2006, 02:12 PM   #3 (permalink)
Ernie Leimkuhler
Guest
Posts: n/a
In article
<10b28181ed83748ff2f4e0393a5f8ce4@localhost.talkaboutautos.com>,
"mad7777777" <marcel_duke@nospam.sympatico.ca> wrote:
[color=blue]
> What did you use for a new chain?[/color]
I simply replaced the chain, guides, tensioner and both sprockets, with
factory spec new parts.
[color=blue]
> Did it have two different sets of marks?[/color]
The marks are immaterial.
I have done 4 head gaskets on 22Rs in the last 2 months.
Once you have done a few you realize that with the main crank shaft set
"spline key up", lower sprocket mark down, the engine at top dead
center, the mark on the top sprocket mark should be a few degrees to the
left (passenger side).
[color=blue]
> You may have to advance your timing a little.[/color]
I tried that and didn't gain anything.
[color=blue]
> both cams?[/color]
Not sure.
The RV cam was a gift from a friend who tried it in his 4WD briefly.
It didn't give him enough power boost, so he went up to a level 3 cam.
It is supposedly the stock cam for toyota commercial chassis', factory
flatbeds, Chinook RVs and Uhaul trucks with 22R motors.
From what I can find on the web, no engine modifications should be
necessary to use an RV cam, but there is no info as to how to tune to
one.
CWI/CWE
WABO Examiner
Old 06-05-2006, 02:48 PM   #4 (permalink)
Evil4Runner
Guest
Posts: n/a
View Evil4Runner's Photo Gallery
Ernie Leimkuhler wrote:[color=blue]
> Standard NGK Plugs.
> difference.
> This is a 2WD hybrid truck.[/color]
[color=blue]
> and 5 bolt fronts.
> CWI/CWE
> WABO Examiner[/color]
I used to have the same problem, i put a new crowel cam to my 94
4runner 22re but most of the mechanic do not know how to ajust the
timing because they need a special method to do it, so try to find
someone with that special tool. Hope u solve your problem.
4runner 1994 With a rare 22RE
Old 06-06-2006, 08:36 AM   #5 (permalink)
Ernie Leimkuhler
Guest
Posts: n/a
Re: 22RE RV Cam adjustments, possible solution.
In article <1149536929.235356.79200@h76g2000cwa.googlegroups.com>,
"Evil4Runner" <jkamberos@hotmail.com> wrote:
[color=blue]
> Ernie Leimkuhler wrote:[color=green]
> > Standard NGK Plugs.
> > difference.
>[color=green]
> > and 5 bolt fronts.
> > CWI/CWE
> 4runner 1994 With a rare 22RE[/color]
I emailed both dealers selling 22R RV cams on Ebay, and one emailed back
to change the valve lash from 0.008" intake and 0.012" exhaust, to
0.007" intake and 0.009" exhaust.
I reset my valves last night and ZOOM... BIG difference.
Lots more power.
I will let you guys know how it turns out.
CWI/CWE
WABO Examiner
Old 06-06-2006, 06:42 PM   #6 (permalink)
Ernie Leimkuhler
Guest
Posts: n/a
In article <ernie-293FD4.06360206062006@news.west.earthlink.net>,
Ernie Leimkuhler <ernie@stagesmith.com> wrote:
[color=blue]
>[color=green]
> > Ernie Leimkuhler wrote:[color=darkred]
> > > Standard NGK Plugs.
> > > difference.
> >[color=darkred]
> > > and 5 bolt fronts.
> > > CWI/CWE
> Lots more power.
> I will let you guys know how it turns out.[/color]
I reset my valve lash to 0.007" intake and 0.009" exhaust, and
ZOOOOOM....
The truck is much happier.
Lots more power.
CWI/CWE
WABO Examiner
Old 06-10-2006, 05:49 PM   #7 (permalink)
William Brown
Guest
Posts: n/a
View William Brown's Photo Gallery
Hey!
Did you adjust those valves Hot or Cold?
Bill
[color=blue][color=green]
>> Lots more power.
>>[/color][/color]
Old 06-11-2006, 08:41 AM   #8 (permalink)
Ernie Leimkuhler
Guest
Posts: n/a
In article <z%Hig.163544$Fs1.21150@bgtnsc05-news.ops.worldnet.att.net>,
"William Brown" <william.j.brown@worldnet.att.net> wrote:
[color=blue]
> Hey!
> Bill
>[/color]
Warm.
I am not enough of a masochist to adjust them hot.
I am pretty happy with how the engine is running now.
It misfires a little at idle, but at rev it runs smooth.
Now I just need to do the clutch so I can take advantage of all that
torque.
[color=blue][color=green][color=darkred]
> >> Lots more power.
> >>[/color][/color][/color]
CWI/CWE
WABO Examiner
Old 06-11-2006, 12:15 PM   #9 (permalink)
Bruce L. Bergman
Guest
Posts: n/a
View Bruce L. Bergman's Photo Gallery
On Sun, 11 Jun 2006 13:41:37 GMT, Ernie Leimkuhler
<ernie@stagesmith.com> wrote:[color=blue]
> "William Brown" <william.j.brown@worldnet.att.net> wrote:[/color]
>> Hey!
>> Bill
>>[/color]
>Warm.
>I am not enough of a masochist to adjust them hot.[/color]
Liar. ;-P I know you own at least one pair of welding gloves, pick
an old throw-away pair that you can get some oil on.
[color=blue]
>It misfires a little at idle, but at rev it runs smooth.[/color]
Duh! You just put in a high-lift cam, of COURSE the idle is going
to be a bit lumpy. You want smooth, you leave the factory bump-stick.
[color=blue]
>torque.[/color]
Do NOT go for the Mega Race Super clutch - all you'll get is
thrashed main bearings. The thrust bearing on Toys isn't all that
robust, you'll just shove the crank out the front of the block.
Someone just had that problem here a few weeks ago...
The stock clutch will work just fine, as long as you don't slip it
too much. Dad had several Toyota Dolphin Class C motorhomes with
R-motors and all special-ordered with sticks. All were loaded well
past the original GVWR with 'siamese' dual wheels and tag axles.
He drove them ~100K miles each for work (the break-in period) with a
lot of hill-climb trips over the Grapevine and to Vegas, and then sold
them private party. And never once had clutch troubles.
--<< Bruce >>--
Bruce L. Bergman, Woodland Hills (Los Angeles) CA - Desktop
Electrician for Westend Electric - CA726700
5737 Kanan Rd. #359, Agoura CA 91301 (818) 889-9545
Spamtrapped address: Remove the python and the invalid, and use a net.
BB code is Off
Smilies are Off
[IMG] code is Off
most hp on a 22rte motor 79toy Pre-88 Toyota Pickup/Hilux 1 04-25-2006 08:57 PM
1MZ Cam marks won't align dgspencer Camry & Solara Lounge 5 03-15-2006 08:32 PM
Part 2: Advancing cam timing allblackalltrac Hardcore Tech and Competition 0 04-16-2004 05:27 PM
Every one say hello to Euro Cam II (warning 19 pics) EuroCamz Camry & Solara Lounge 39 04-01-2004 05:03 PM
