Re: 86 pickup Turbocharger replacement with a Supercharger
On Tue, 20 Jun 2006 07:01:59 GMT, "William Brown"
<william.j.brown@worldnet.att.net> wrote:
[color=blue]
>After much investigation i've decided to forgo the Supercharger kit and stay with the turbo.
>Seems like it's almost impossible to get an LCS Supercharger Kit to pass California emissions test.
>I've got a TEC bolt in replacement kit here for the Toyota CT-20 junk. It's a Garrett T-3 with all
>the adapters, lines and even a downpipe. I plan to do everything i can think of to get rid of heat
>in the engine compartment. Mount a larger oil cooler above the lower oil pan shield. Relocate the
>battery and install a side mount intercooler (supra style) in it's place while opening the closed fins
>on the grill in that area and direct fresh air to the cooler with a dam. Even install a 4 row aluminum
>radiator in place of the 3 row stock copper radiator.
>Anybody have any other ideas to help keep it cool?[/color]
I'd try to find a 4-row Copper radiator, they tend to last a whole
lot longer, and are much easier to repair. The stupid Aluminum ones
tend to have the crimped-on plastic tanks, and are disposable - often.
Reducing weight is less important than function and reliability.
Does the Garrett have the water-cooled center section?
I'd think the hot ticket would be to find a small 12V gear pump and
build a totally separate oiling system for the Turbo bearings - small
1 or 2 liter reservoir, small electric oil pump, small cooler in the
grille (Power Steering size), micron oil filter, return to tank.
Turbo oil pressure (entering) and temperature (leaving) gauges. Low
oil tank level micro float-switch, oil pressure idiot light sender,
common "TURBO" idiot light for both.
You can pick an oil that is specific to the turbo needs, probably a
lighter weight Mobil1 Synthetic than you'd want to run in the engine.
Ask the folks at Garrett what oil they would use if engine oiling
compatibility wasn't an issue. And pre-lubing and post-lubing would
be drop-dead simple - turn the key on and pause for the pre-lube, with
a cool-down timer for the oil pump.
--<< Bruce >>--
