I have a 98 Tacoma 4X4 with 96,000 miles, automatic, 4 cylinder.
It runs great, but when I stop at a traffic light, etc., it idles
rough. Does not seem to be a low idle. I usually put it in neutral and
it helps a little. I'm not tech savvy with the newer automotive
electronics (was shocked to find there was no distributor!) so please
keep it simple. Also, as a missionary in El Salvador, the technology to
test and qualified mechanics are rare if they exist at all. Please
advise.
"ElBob" <caom336@hotmail.com> wrote in message
news:1149774542.069982.319370@f6g2000cwb.googlegroups.com...[color=blue]
> advise.
>[/color]
First thing to check would be plugs and wires, how long sinse the last
tune-up? You may just need the throttle body cleaned, if it has never been
done before.
Mike wrote:[color=blue]
> news:1149774542.069982.319370@f6g2000cwb.googlegroups.com...[color=green]
> > advise.
> >[/color]
> done before.[/color]
I changed the plugs, air and fuel filters and it did not seem to have
any affect. If it we back in the 70's I would suspect a vacuum problem.
Does this seem likely? When accelerating it runs fine, no hesitation,
etc.
news:1149800111.910799.190240@u72g2000cwu.googlegroups.com...[color=blue]
> Mike wrote:[color=green]
>> news:1149774542.069982.319370@f6g2000cwb.googlegroups.com...[color=darkred]
>> > advise.
>> >[/color]
>> been
> etc.
>[/color]
A vacuum leak may be a possibility. On fuel injected cars a small vacuum
ussualy will cause an increase in idle speed as the computer is able to
compensate to a small degree. A large leak would likely cause a hesitation
and may turn on the check engine light. You can check for a vacuum leak by
spraying carb cleaner at the intake gaskets and vacuum lines. You will
notice a change in engine rpm's if you find the leak. You may need to hook
it up to a decent scan tool that will let you read the sensor values while
the vehicle is running to determine what is wrong.
