Roll-starting a vehicle - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota USENET Discussion Groups > alt.autos.toyota > alt.autos.toyota.trucks
alt.autos.toyota.trucks Toyota Trucks discussion newsgroup.
Old 06-08-2006, 11:50 AM   #1 (permalink)
Brad P
Guest
Posts: n/a
View Brad P's Photo Gallery
Is roll-starting the engine hard on a manual transmission?
Old 06-08-2006, 12:14 PM   #2 (permalink)
Jarhead
Guest
Posts: n/a
View Jarhead's Photo Gallery
Re: Roll-starting a vehicle
"Brad P" <bradp_xx@hotmail.com> wrote in message
news:hzYhg.19362$A26.442629@ursa-nb00s0.nbnet.nb.ca...
No! Just don't use first gear. Use 2nd gear, release the clutch
smoothly and be ready to disengage the clutch when it starts. I haven't
had to do this for many years but have never experienced any ill effects
from starting my car or truck this way.
Jarhead
----== Posted via Newsfeeds.Com - Unlimited-Unrestricted-Secure Usenet News==----
[url]http://www.newsfeeds.com[/url] The #1 Newsgroup Service in the World! >100,000 Newsgroups
---= East/West-Coast Server Farms - Total Privacy via Encryption =---
Old 06-08-2006, 12:47 PM   #3 (permalink)
Brad P
Guest
Posts: n/a
"Jarhead" <baldintexas@excite.com> wrote in message
news:1149786469_11155@sp6iad.superfeed.net...[color=blue]
> Jarhead
>[/color]
Cool..thanks for the reply!
Old 06-08-2006, 03:19 PM   #4 (permalink)
DruG
Guest
Posts: n/a
View DruG's Photo Gallery
also another point. On a few of the vehicles I've roll started if the
battery was completely dead it took quite a decent hill to spin the engine
enough so that the fuel pump would power up and the car would actually run.
I'd always just try and give it gas then as soon as it accelerated I'd pop
it into neutral and let the battery charge for a bit.
Also it is possible to roll start an automatic but I'd only try that on a
rental.
Cheers,
-Dru
news:cpZhg.19389$A26.442802@ursa-nb00s0.nbnet.nb.ca...[color=blue]
> news:1149786469_11155@sp6iad.superfeed.net...[color=green]
>> Jarhead
>>[/color]
>[/color]
Old 06-08-2006, 06:44 PM   #5 (permalink)
M. Cantera
Guest
Posts: n/a
View M. Cantera's Photo Gallery
Is is real easy on a carburated engine (that is how you start a
lawnmower)
Is is possible, but not recommended, on a engine with indirect fuel
injection. There is no power to the computer and the sensors, it may
not fire at all if there is no residual pressure in the fuel lines.
You may meed a hill to let gravity supply enough rpm to the the
generator going.
It is next to impossible on a direct injected engine. The injector
pump has to generate enough pressure for the injection to occur
On Thu, 08 Jun 2006 16:50:21 GMT, "Brad P" <bradp_xx@hotmail.com>
wrote:
[color=blue]
>Is roll-starting the engine hard on a manual transmission?[/color]
Old 06-08-2006, 08:07 PM   #6 (permalink)
davidj92
Guest
Posts: n/a
View davidj92's Photo Gallery
DruG wrote:[color=blue]
> rental.
> Cheers,
> -Dru[/color]
I stand to be corrected but it's been quite a few years
since you could roll start an automatic. When they did away
with the rear pump the trans would no longer turn the engine
over.
Dave
Old 06-09-2006, 05:05 AM   #7 (permalink)
Scotty
Guest
Posts: n/a
View Scotty's Photo Gallery
"DruG" <drudadFSPAM@dccnet.com> wrote in message
news:128h1mtfd6pd5f4@corp.supernews.com...[color=blue]
> run. I'd always just try and give it gas then as soon as it accelerated
> I'd pop it into neutral and let the battery charge for a bit.
> rental.[/color]
The speed that the auto will lock up is around 50MPH but unlikely to get
that fast when just rolling down a hill, you would need to be towed then if
theres another vehicle there you could just jump start it. (Thats a whole
new thread on how to properly jump a vehicle but if anyones interested....)
Old 06-09-2006, 05:07 AM   #8 (permalink)
Scotty
Guest
Posts: n/a
"M. Cantera" <cantera_2@RemoveThis.netzero.com> wrote in message
news:76dh829ed7e7e1dr24r6sfp31ngjed7aq7@4ax.com...[color=blue]
> lawnmower)
> generator going.
> wrote:
>[color=green]
>[/color]
If the battery has no charge what-so-ever you probably wont roll start it as
the alternator requires a voltage to get charging started to supply power to
the coil(s).
Old 06-09-2006, 09:19 AM   #9 (permalink)
Jarhead
Guest
Posts: n/a
"davidj92" <davidj92LOCK@sigecom.net> wrote in message
news:7NednZuw5uhVVBXZnZ2dnUVZ_omdnZ2d@sigecom.net...
the
engine
actually run.
I'd pop
on a
| > rental.
| > Cheers,
| > -Dru
| over.
| Dave
Reminds me of an old, old joke.
This guy was stranded along the highway and a woman stopped to see if
she could help.
He said, "His battery was dead and he couldn't push start his car."
She said, "Why not?"
He said, "Because it has an automatic transmission and the car has to be
going at least 35 mph to turn the engine over."
She says, "That's not a problem.", and turns around to get her car
behind him.
He looks up in his rear view mirror and sees her coming up behind him at
40mph.
Jarhead
Old 06-09-2006, 10:27 AM   #10 (permalink)
DruG
Guest
Posts: n/a
"Scotty" <scoter1@warmmail.com> wrote in message
news:448947d5$0$10288$afc38c87@news.optusnet.com.au...[color=blue]
> news:128h1mtfd6pd5f4@corp.supernews.com...[color=green]
>> engine enough so that the fuel pump would power up and the car would
>> actually run. I'd always just try and give it gas then as soon as it
>> accelerated I'd pop it into neutral and let the battery charge for a bit.
>> rental.[/color]
> if theres another vehicle there you could just jump start it. (Thats a
> whole new thread on how to properly jump a vehicle but if anyones
> interested....)
>[/color]
Admittedly I haven't seen more than 1 roll started but it was a 99 or so
Ford Crew Cab Truck. It would periodically not start for no good reason and
so one day out on the block we were all pissed off and decided to try and
roll start it. We were up in the mountains so we had a pretty good hill to
go for it. We got it up to around 60 and then popped er into drive and she
started.
Old 06-09-2006, 09:05 PM   #11 (permalink)
davidj92
Guest
Posts: n/a
Jarhead wrote:[color=blue]
> the
> engine
> actually run.
> I'd pop
> on a
> | > rental.
> | > Cheers,
> | > -Dru
> | over.
> | Dave
> she could help.
> behind him.
> 40mph.
>[/color]
That joke is still funny. Thanks, I got a chuckle out of that.
Old 06-10-2006, 10:36 AM   #12 (permalink)
Jeff Strickland
Guest
Posts: n/a
View Jeff Strickland's Photo Gallery
It depends.
If you do it all of the time, it can be hard on the drive train, but if it
is a way to work around a dead battery, then the harm is mimimal, and is
offset by the obvious benefit of getting the motor to run.
Select the highest possible gear that will get the motor turning, generally
2nd works when the car is pushed by people, and 3rd is good if you get a
push by another vehicle.
news:hzYhg.19362$A26.442629@ursa-nb00s0.nbnet.nb.ca...[color=blue]
>[/color]
Old 06-10-2006, 10:38 AM   #13 (permalink)
Jeff Strickland
Guest
Posts: n/a
> rental.
>[/color]
I would descourage any attempt to push-start a car that is equipped with an
automatic trans. The transmission will not usually turn the motor over.
BB code is Off
Smilies are Off
[IMG] code is Off
Bolt in Roll Bar and Cage Kits Starting at just $269.95 with this sale!!! Safe Drives Supporting Vendor Sales 15 02-14-2007 01:05 PM
What's up with the Kelley Blue Book c@mry General Discussion 9 10-20-2005 08:28 AM
North County Toyota of Anaheim xpeed Toyota Dealers 3 09-27-2005 10:58 AM
More gas on PZEV (in CA) vehicle than others? kthan General Discussion 0 09-11-2005 05:58 PM
could you get away with it bondobondo General Discussion 46 07-06-2002 12:00 PM
