1996 TACOMA HARD TO START WHEN WARM - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota USENET Discussion Groups > alt.autos.toyota > alt.autos.toyota.trucks
alt.autos.toyota.trucks Toyota Trucks discussion newsgroup.
Old 06-08-2006, 10:43 PM   #1 (permalink)
woodbatch
Guest
Posts: n/a
View woodbatch's Photo Gallery
Have a 1996 Tacoma. Runs great but when you turn it off you have to wait 30
to 45 min. to restart or it will just turn over and not get ignition. Im
thinking it has something to do with the injectors or maybe a sensor. Any
suggestions.
Old 06-09-2006, 12:39 PM   #2 (permalink)
Mike
Guest
Posts: n/a
View Mike's Photo Gallery
Re: 1996 TACOMA HARD TO START WHEN WARM
"woodbatch" <woodbatch@aol.com> wrote in message
news:c64da0cde83094c07562d1e1d074bf8a@localhost.talkaboutautos.com...[color=blue]
> 30
> suggestions.
>[/color]
You state that it turns over and will "not get ignition". Do you mean it
has no spark or that it just won't start ? If you are saying that it has no
spark you need to look at the ignition system. That would have nothing to do
with the injectors.
Old 06-09-2006, 02:29 PM   #3 (permalink)
Mike Harris
Guest
Posts: n/a
View Mike Harris's Photo Gallery
> 30
> suggestions.[/color]
Before you do anything, you should be aware that the Tacoma fuel injection
is programmed with a "hot start" mode.
Before you turn the key, push the accelerator pedal all the way to the floor
and hold it. This will keep the FI "brain" from richening the mixture for
the start.
Mike Harris
Austin, TX
List owner, Toy_Coma [url]http://autos.groups.yahoo.com/group/Toy_Coma/[/url]
Old 06-09-2006, 08:18 PM   #4 (permalink)
Mike
Guest
Posts: n/a
"Mike Harris" <harrisremovethiswest@sbcglobal.net> wrote in message
news:t_jig.40950$4L1.511@newssvr11.news.prodigy.com...[color=blue]
> news:c64da0cde83094c07562d1e1d074bf8a@localhost.talkaboutautos.com...[color=green]
>> 30
> floor and hold it. This will keep the FI "brain" from richening the
> mixture for the start.
> Mike Harris
> Austin, TX
>[/color]
There is no need to hold the acceleator to the floor when starting a hot
engine. There is no need to even touch the accelerator on a fuel injected
vehicle when starting it. In fact, on any fuel injected vehicle, holding the
accelerator to the floor while starting is not reccomended unless the
vehicle is flooded. When you hold the accelerator to the floor it causes the
computer to stop fuel delivery to clear a flooded condition. If it's not
flooded it won't start because it won't be getting any fuel.
Old 06-13-2006, 02:51 AM   #5 (permalink)
Joseph Wind
Guest
Posts: n/a
View Joseph Wind's Photo Gallery
Sounds like a bad Air Mass Meter. Does the engine, when running also run a
bit rough?
> Have a 1996 Tacoma. Runs great but when you turn it off you have to wait[/color]
30[color=blue]
> suggestions.
>[/color]
Old 06-19-2006, 09:19 PM   #6 (permalink)
Ken
Guest
Posts: n/a
View Ken's Photo Gallery
Hi Mike,
I have the same issue, however I have a CEL on - error code is that the
front 02 sensor is N/g. Also when emissions tested; failed as "running
to lean". My guess is the too lean issue causes a vapor lock when it is
too hot (or something like that). Playing with the gas pedal will get
it started MUCH earlier than the wait time you describe.
Problem I have is the 02 sensor was already replaced last year,
supposedly, although I suspect the old one was just reconnected and
attached - my brother-in-law owned it then and just before I bought it
the same garage said "oh. maybe it was the rear one.
Now the code says (again) the front sensor is n/g per Autozone.
Downside is it will co$t to try my theory. Also I have an exhaust leak
AFTER the catalytic, but before the 2nd sensor.
Not sure what to believe, but it seems that if the front sensor was
working and the 2nd didnot seefull exhaust, then if anything it should
run richer as the 2nd sensor is seeing less exhaust. But then you get
into ppm etc. etc.
Dealar basically wants to just basically replace the entire car, which
is honestly not honest.
Digging through the Internet now....
Mike Harris wrote:[color=blue]
> > 30
> the start.
> Mike Harris
> Austin, TX
> List owner, Toy_Coma [url]http://autos.groups.yahoo.com/group/Toy_Coma/[/url][/color]
Old 06-21-2006, 10:56 AM   #7 (permalink)
Andy Hill
Guest
Posts: n/a
View Andy Hill's Photo Gallery
"Ken" <kaeemgonc@gmail.com> wrote:[color=blue]
>Hi Mike,
>into ppm etc. etc.
>[/color]
Did Autozone tell you the exact failure code? Hard to interpret "front O2
sensor is N/G".
What engine and what year? The V6 engines in the mid-90's Tacos have two O2
sensors upstream of the cat (one for each bank), and a single O2 sensor
downstream of the cat. If it's a 4-banger, then you have one upstream and one
downstream O2 sensor.
The O2 sensor downstream of the cat isn't involved in the fuel mixture
calculations -- it's just there to monitor the efficiency of the cat.
BB code is Off
Smilies are Off
[IMG] code is Off
86 Tercel Wagon hard start Chink Tercel, Paseo, Starlet, and Sera Forum 1 08-21-2004 05:54 PM
help- hard to start FRITO Camry & Solara Lounge 13 11-15-2003 11:10 AM
Hard Warm Start on 4Runner cratz2 4Runner Lounge 3 08-05-2003 12:41 PM
