Removing rear oil seal retainer 1984 22R engine - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota USENET Discussion Groups > alt.autos.toyota > alt.autos.toyota.trucks
alt.autos.toyota.trucks Toyota Trucks discussion newsgroup.
Old 06-12-2006, 10:09 PM   #1 (permalink)
jbclem
Guest
Posts: n/a
View jbclem's Photo Gallery
In the middle of a clutch job on my 1984 longbed pickup, have removed the 7 bolts for
the rear oil seal retainer (to replace the rear oil seal) and the retainer is not
exactly coming out easily. I don't wedge a screwdriver in the crack and I'm not sure if
I should whack it to break it loose. The books I have make it seem like a very easy job
(just remove it and replace the seal, they sez, just like that!) but these same manuals
(including some online ones) don't mention the gasket behind the retainer nor what the
torque is for the bolts.
I don't see any lips I can use for leverage and by the sound I can tell the retainer is
slightly loose...but it isn't budging. Any suggestions or tricks for getting it out.
Also, the books don't mention the retainer gasket, is this a dealer item or can the old
one be reused if it is good?
jc
Old 06-13-2006, 10:31 PM   #2 (permalink)
View xsacta's Photo Gallery
Have you removed the oil pan? It'll be tough to remove the retainer with the oil pan installed. Maybe impossible.
xsacta is offline   Reply With Quote
Old 06-14-2006, 07:08 AM   #3 (permalink)
SnoMan
Guest
Posts: n/a
View SnoMan's Photo Gallery
Re: Removing rear oil seal retainer 1984 22R engine
On Tue, 13 Jun 2006 23:31:43 -0400, xsacta
<xsacta.29dhob@no-mx.forums.yourdomain.com.au> wrote:
[color=blue]
>the oil pan installed. Maybe impossible.[/color]
Yep, that is the toyota way. Make sure you reseal the pan properly too
especailly in the rear seal area.
The SnoMan
[url]www.thesnoman.com[/url]
BB code is Off
Smilies are Off
[IMG] code is Off
Low oil pressure after timing belt & oil pump seal change Hot66ss Camry & Solara Lounge 9 05-07-2006 08:44 AM
Supra Specs and time frames? glish_dreams Supra Forum 17 04-17-2006 11:14 PM
