New clutch disk, which side points where? - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota USENET Discussion Groups > alt.autos.toyota > alt.autos.toyota.trucks
alt.autos.toyota.trucks Toyota Trucks discussion newsgroup.
Old 06-14-2006, 08:56 PM   #1 (permalink)
jbclem
Guest
Posts: n/a
View jbclem's Photo Gallery
One more question from my 1984 Toyota Pickup 2WD carburated clutch job. I'm getting
conflicting information about which direction the clutch disk should point, and I didn't
check the old one before I took it out.
One manual says " The side of the disc that has the springs sticking out goes towards
the transmission " but you can see the springs from both sides. There is one side that
has the springs retainer plate and so the springs are thicker on that side but I'm not
sure that's what the manual means.
Another manual says "on pickups, the short side of the splined section faces the
flywheel" but the problem is that if you measure the splined section on how far it
sticks out from the center of the disk, each side is about the same length. If you
measure it from where it visibly sticks out, then the side of the disk with the springs
retainer plate has less of the splined section showing. The problem is that if this is
what you go by, then this manual's advice is the exact opposite of the other manual's
advice.
So I'm really confused and hoping someone out there has a clearer way to explain this
dilemma.
John
Old 06-15-2006, 04:20 AM   #2 (permalink)
Scotty
Guest
Posts: n/a
View Scotty's Photo Gallery
Re: New clutch disk, which side points where?
"jbclem" <jbclem1@charter.net> wrote in message
news:683kg.273$nh2.99@fe04.lga...[color=blue]
> I'm getting
> point, and I didn't
> goes towards
> one side that
> but I'm not
> faces the
> how far it
> length. If you
> with the springs
> that if this is
> other manual's
> advice.
> explain this
> dilemma.
> John
>[/color]
Side which purtrudes furthest goes towards the transmission.
Old 06-15-2006, 04:50 AM   #3 (permalink)
jbclem
Guest
Posts: n/a
That makes sense, there is more room inside the clutch cover than inside the flywheel
hollow.
Now I have another question...can someone explain exactly how the throwout bearing clips
go, or direct me to a good photograph that show how they interface with the fork.
Thanks, John
"Scotty" <scoter1@warmmail.com> wrote in message
news:4491264a$0$26421$afc38c87@news.optusnet.com.au...[color=blue]
> news:683kg.273$nh2.99@fe04.lga...[color=green]
> > I'm getting
> > point, and I didn't
> > goes towards
> > one side that
> > but I'm not
> > faces the
> > how far it
> > length. If you
> > with the springs
> > that if this is
> > other manual's
> > advice.
> > explain this
> > dilemma.
> > John
> >[/color]
>[/color]
BB code is Off
Smilies are Off
[IMG] code is Off
Custom Tercel Body Kit TeRcElIcA Tercel, Paseo, Starlet, and Sera Forum 19 12-30-2009 01:49 AM
Urgent; hi performance clutch question sloppybeak General Discussion 0 03-27-2006 08:24 PM
Soft Clutch + Can't shift into / out of gear !! noobiedoobiedo Camry & Solara Lounge 6 03-20-2006 08:21 AM
Clutch problem, seeking help. blueapple Celica Forum 0 01-21-2006 12:17 AM
Major traffic infraction fines and demerit points Dredd2099 General Discussion 12 06-26-2003 10:27 PM
