A/C problem solutions? - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota USENET Discussion Groups > alt.autos.toyota > alt.autos.toyota.trucks
alt.autos.toyota.trucks Toyota Trucks discussion newsgroup.
Old 06-15-2006, 12:06 PM   #1 (permalink)
rigger
Guest
Posts: n/a
View rigger's Photo Gallery
Hi all,
I've got a 1994 4runner that blows the 10 amp A/C fuse whenever I try
to run the A/C. I've checked all the outputs from the amplifier board
and none are shorted (except of course the ground connection) so I'm
guessing the magnetic clutch and relays are ok. Does this then mean
the board is shorting to ground internally and needs to be replaced?
I hope someone has seen this before as no one around here has.
Thanks for any help you can give me.
dennis
in nca
Old 06-15-2006, 12:38 PM   #2 (permalink)
SnoMan
Guest
Posts: n/a
View SnoMan's Photo Gallery
Re: A/C problem solutions?
On 15 Jun 2006 10:06:11 -0700, "rigger" <dgrup@aol.com> wrote:
[color=blue]
>Hi all,
>dennis
>in nca[/color]
Check for shorts in underhood wiring to compressor and for a shorted
compressor clutch coil too.
The SnoMan
[url]www.thesnoman.com[/url]
Old 06-15-2006, 04:34 PM   #3 (permalink)
Dave
Guest
Posts: n/a
View Dave's Photo Gallery
[color=blue]
>Hi all,
>[/color]
Are you sure it's supposed to be a 10 amp?
All mine are 30 amp, newer vehicles but still 10 amp is very low.
Old 06-16-2006, 12:18 PM   #4 (permalink)
rigger
Guest
Posts: n/a
SnoMan wrote:
[color=blue]
> The SnoMan
> [url]www.thesnoman.com[/url][/color]
Thanks for responding:
No shorts I can find. Would you or anyone else know the correct
resistance for the clutch? It's not at a dead short at this time but
perhaps it's only partially shorted? :(
dennis
in nca
Old 06-16-2006, 12:21 PM   #5 (permalink)
rigger
Guest
Posts: n/a
Dave wrote:[color=blue]
> "rigger" <dgrup@aol.com> wrote:[color=green]
> >[/color]
> All mine are 30 amp, newer vehicles but still 10 amp is very low.[/color]
On this 4runner the 10 amp feeds the A/C amplifier which feeds a couple
of relays and a thermister in addition to the A/C clutch. There's also
a 20 amp which feeds the blower motor, etc.
dennis
in nca
Old 06-16-2006, 12:23 PM   #6 (permalink)
rigger
Guest
Posts: n/a
rigger wrote:[color=blue]
> Hi all,
> dennis
> in nca[/color]
Would anyone know of other groups or sites that might have some info?
Thanks all.
dennis
in nca
Old 06-16-2006, 06:17 PM   #7 (permalink)
Paul.
Guest
Posts: n/a
View Paul.'s Photo Gallery
Have you tried to unplug the magnetic clutch and measure voltage at the
plug. If you get proper voltage and the fuse doesn't blow, it points to the
magnetic clutch. If it does blow the fuse, keep searching but you know it's
not the magnetic clutch.
Paul.
"rigger" <dgrup@aol.com> wrote in message
news:1150391171.359542.259590@i40g2000cwc.googlegroups.com...[color=blue]
> Hi all,
> dennis
> in nca
>[/color]
Old 06-16-2006, 10:45 PM   #8 (permalink)
rigger
Guest
Posts: n/a
Paul. wrote:[color=blue]
> Paul.
> news:1150391171.359542.259590@i40g2000cwc.googlegroups.com...[color=green]
> > Hi all,
> > dennis
> > in nca
> >[/color][/color]
Thanks Paul. That sounds like a good idea; I'll try it in the morning.
dennis
Old 06-17-2006, 06:55 PM   #9 (permalink)
rigger
Guest
Posts: n/a
> Paul. wrote:[color=green]
> > Paul.[/color]
> dennis[/color]
Well I isolated it to the clutch (or wiring to same).
Couldn't get at the wire loom connection (it's buried on top of the
compressor); I can't reach it without pulling the compressor. What I
did was to hammer out flat the ends of some finishing nails and put
these ends into the amplifier connector and used jumpers (from Radio
Shack) to connect to the board. I didn't connect the power wire to the
compressor clutch (black with yellow stripe) and when I fired it up the
fuse did not blow. On the other hand, with this hooked up with the
clutch wire in the circuit "POW", one more fuse bites the dust.
Looks like another job is on the list.
Thanks to everyone for reading and for those who could help.
dennis
in nca
Old 06-21-2006, 07:27 PM   #10 (permalink)
Paul.
Guest
Posts: n/a
From a post on A/C problems, some good reading on the controls associated
with the A/C.
Paul.
Info tip I found:
<http://www.findarticles.com/p/articles/mi_qa3828/is_200206/ai_n9092114>
just right click -highlight & copy and paste in your address bar to open.
> Hi all,
> dennis
> in nca
>[/color]
Old 08-03-2006, 06:14 PM   #11 (permalink)
Danny G.
Guest
Posts: n/a
View Danny G.'s Photo Gallery
"rigger" <dgrup@aol.com> wrote in message news:1150391171.359542.259590@i40g2000cwc.googlegroups.com...[color=blue]
> Hi all,
> dennis
> in nca
>[/color]
Check the resistance of the stator coil (magnetic clutch) with a ohm meter.
Mine was damaged from battery acid (I guess) and blowing the fuse just like that
with 2.6 ohms resistance. It worked fine when testing with a 12 volt (15 amp fuse) power source
and fooled me for quite awhile. :/
1987 Supra stator coils resistance shows 2.7 - 3.1 ohms at 68f degree
GL
Dan
Old 08-03-2006, 07:19 PM   #12 (permalink)
SnoMan
Guest
Posts: n/a
On Thu, 03 Aug 2006 23:14:33 GMT, "Danny G." <dandog@pacbell.net>
wrote:
[color=blue]
>and fooled me for quite awhile. :/[/color]
Just remember that a magnetic coild has static resistance and a actaul
impedance when powered and clutch pulled in. (it will vary)
The SnoMan
Old 08-04-2006, 03:05 PM   #13 (permalink)
Danny G.
Guest
Posts: n/a
"SnoMan" <admin@snoman.com> wrote in message news:bj45d21ip95fu1hs4rnis7c0qpf1dinu54@4ax.com...[color=blue]
> wrote:
>[color=green]
> The SnoMan
Woops, forgot to type the specified range was 2.7 - 3.2 ohms at 68f degree.
8)
Old 08-04-2006, 03:15 PM   #14 (permalink)
SnoMan
Guest
Posts: n/a
On Fri, 04 Aug 2006 20:05:04 GMT, "Danny G." <dandog@pacbell.net>
wrote:
[color=blue]
>"SnoMan" <admin@snoman.com> wrote in message news:bj45d21ip95fu1hs4rnis7c0qpf1dinu54@4ax.com...[color=green]
>> wrote:
>>[color=darkred]
>> The SnoMan
>8)
>[/color]
What you are really looking for here is a short or a open (a short in
this case because a 2.5 ohm reading or a bit less does not always mean
it is bad.
The SnoMan
BB code is Off
Smilies are Off
[IMG] code is Off
2005 Corolla LE dashboard/door alignment problem richs Archived Corolla threads 8 09-21-2005 04:02 PM
A/C dont work with new Dash, Camry Forum is clueless ? ? ? avalon01 Audio, Video, and Security - Tech 16 08-29-2005 09:11 AM
88 Camry A/C help bluedevil 1st & 2nd Generation (1983–1986 & 1987-1991) 9 06-09-2004 09:37 PM
A/C Amplifier oldsub86 Camry & Solara Lounge 0 10-28-2003 06:11 PM
