Re: Insturment Panel swap 86 Pickup
Easy swap - make sure you get the sending unit for the oil pressure switch
as it is different. You may have to run a wire for the tach but that's it.
Also get one from a 4 cylinder and not a 6 as the speedo is geared
differently. Check out:
[url]http://www.brian894x4.com/Gaugecluster.html[/url]
"Joseph Wind" <jpg@gif.com.invalid> wrote in message
news:j3Fkg.3687$YI2.3498@trnddc01...[color=blue]
>I want to change my Instrument panel on my 86 Toyota 22R Automatic Pickup.
>I want to have a tachometer like in the SR5 model. Is it possible to swap
>one in with out too much modification? I was told the connector are
>already there, you just have to plug it in.
> Thanks in advance.
>[/color]
