Wheel Bearings - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota USENET Discussion Groups > alt.autos.toyota > alt.autos.toyota.trucks
alt.autos.toyota.trucks Toyota Trucks discussion newsgroup.
Old 06-17-2006, 08:46 AM   #1 (permalink)
mjv
Guest
Posts: n/a
View mjv's Photo Gallery
Wheel Bearings
I'm about to replace the front wheel bearings on my early 1995 Tacoma
4x4 with auto locking hubs. I haven't done bearings myself since 1997
and I'm feeling a little lost especially as it's my first time with a
4x4. Can anyone offer any insight as to proceedure, common mistakes,
special tools required etc.? It would be greatly appreciated.
Thanks.
Mike
Old 06-17-2006, 09:08 AM   #2 (permalink)
Wolfgang
Guest
Posts: n/a
View Wolfgang's Photo Gallery
Re: Wheel Bearings
Cleaning and repacking them would be just as good unless they are worn/burt
blue or rusty. If used off road and in water replacement probably good
idea. See:
[url]http://www.4x4wire.com/toyota/maintenance/front_end/bearing/[/url]
"mjv" <pob1133@yahoo.com> wrote in message
news:1150551972.152741.91140@p79g2000cwp.googlegroups.com...[color=blue]
> Thanks.
> Mike
>[/color]
Old 06-17-2006, 09:42 AM   #3 (permalink)
JoeSpareBedroom
Guest
Posts: n/a
View JoeSpareBedroom's Photo Gallery
Re: Wheel Bearings
> Thanks.
> Mike
>[/color]
A number of people here have mentioned a site where, for a few bucks, you
get on day of access to service manual info. I *think* this is the site -
take a look:
[url]http://www.techinfo.toyota.com/[/url]
Old 06-17-2006, 10:08 AM   #4 (permalink)
SnoMan
Guest
Posts: n/a
View SnoMan's Photo Gallery
Re: Wheel Bearings
On Sat, 17 Jun 2006 10:08:38 -0400, "Wolfgang"
<NOwolfXgang_dieterxSPAM@NOXcox.netNOT> wrote:
[color=blue]
>idea[/color]
THe appearance of the bearings and their smoothness is the main factor
as they can go 200K plus easy if properly lubed and less than 30K if
not. I would not replace them just for the sake of it if the look
good.
The SnoMan
[url]www.thesnoman.com[/url]
Old 06-18-2006, 08:46 AM   #5 (permalink)
mjv
Guest
Posts: n/a
Re: Wheel Bearings
Thanks for the info. It's been a particularly hard winter on ol' Wanda.
The local forest is void of tourists in the cold, snowy and wet winter.
A lot of water crossings and alot of snow travel. In addition, the left
front wheel has a bit of play so I'll check 'em at the least.
Thanks again to all who've replied.
Mike.
P.S. I've also noticed a "shimmy" when braking hard. Could this be an
idler arm issue?
Wolfgang wrote:[color=blue]
> idea. See:
> news:1150551972.152741.91140@p79g2000cwp.googlegroups.com...[color=green]
> > Thanks.
> > Mike
> >[/color][/color]
Old 06-18-2006, 07:46 PM   #6 (permalink)
View xsacta's Photo Gallery
[QUOTE=mjv]I'm about to replace the front wheel bearings on my early 1995 Tacoma
Thanks.
Mike[/QUOTE]
You haven't mentioned the mileage, so I'll assume it's relatively high. Jack the front of the truck up and rotate the wheels and see if they feel smooth. If you hear or feel a faceted sound(rough) then both bearings and races may need replacement. IMO, replace the bearings and inspect the races. If the races are grooved and uneven replace them too. A bit of a bitch as they're pressed in. AFAIK, there are at least 2 seals per hub that must be replaced also.
xsacta is offline   Reply With Quote
BB code is Off
Smilies are Off
[IMG] code is Off
new owner problems dack41 2nd Generation (2005+) 17 10-04-2006 10:53 PM
How-To: 89+ Non-Airbag Steering Wheel into Pre-89 (MKIII) Jeff Lange Supra Forum 1 10-13-2005 01:17 AM
About rear wheel hubs n bearings soccerman58 Tercel, Paseo, Starlet, and Sera Forum 30 10-05-2005 09:03 AM
where's the best place to buy wheel bearings? baartman Archived Corolla threads 4 03-09-2003 11:10 AM
