Re: Headlight changes, and reverse problems
newbear_nc wrote:[color=blue]
> I have a 93 Toyota truck, and I have two problems which are a bother to me
> at this time. One is the headlights; they are so dim I can barely see
> while driving at night, unless I use the high beams and they are still
> dim. And the second problem is the truck will cut off while in reverse,
> it makes me think it is not idling high enough. I want to know if I can
> get headlights which are made for newer models to fit on my truck, if so
> what would it involve. Can anyone help me?
>[/color]
Do the headlights glow yellow, or are the lenses no longer clear, or
do they aim at the ground?
a) Fix the wiring. Check every wiring connection, especially the
connections to ground, to be sure they are all clean, dry, and tight.
b) You can use any of several brands of plastic polish made by
Meguiar's, Mother's, and others, or buy new aftermarket lights. Do
a Google (or Froogle) search or check eBay.
c) Correctly aim the lights.
