Worn Ignition Key - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota USENET Discussion Groups > alt.autos.toyota > alt.autos.toyota.trucks
alt.autos.toyota.trucks Toyota Trucks discussion newsgroup.
Old 06-18-2006, 10:56 AM   #1 (permalink)
tbl
Guest
Posts: n/a
View tbl's Photo Gallery
Worn Ignition Key
My 1988 Toyota pickup ignition key always gets two very worn
places on the flat sides near the tip of the key (about
3/16" from the tip). It looks like something is rubbing
there a lot, when the key is in the ignition switch, but I
can't imagine what. I'm on my third set of keys, and the
latest set is now showing very noticable wear there.
Anyone?
Thanks,tbl
Old 06-18-2006, 11:46 AM   #2 (permalink)
William Brown
Guest
Posts: n/a
View William Brown's Photo Gallery
Re: Worn Ignition Key
Hey!
Get some lubricant in the keyhole.
I've used graphite powder in the past.
Too many new products on the market to mention.
Maybe the local bicycle or motorcycle shop for some dry lube.
Hope that helps!........................Bill
"tbl" <hate@ThatSpam.net> wrote in message
news:1mta925o9tg4le6h8tl33jt0kqrtikhk8k@4ax.com...[color=blue]
> Anyone?
> Thanks,tbl[/color]
Old 06-18-2006, 01:05 PM   #3 (permalink)
Joseph Wind
Guest
Posts: n/a
View Joseph Wind's Photo Gallery
I usually have problems with the door locks than the ignition switch.It's
the metal the duplicate keys are made of. They are made of a softer metal,
typically brass and tin. I keep one master key to duplicate from, for this
purpose. Master Keys are made of steel.
If all else fails, go to the dealer with your VIN, they can make you a new
key. I had to remove the driver side door lock to get the code for my
truck.
> Anyone?
> Thanks,tbl[/color]
Old 06-18-2006, 02:01 PM   #4 (permalink)
TOM
Guest
Posts: n/a
View TOM's Photo Gallery
tbl wrote:
[color=blue]
> Anyone?[/color]
The original keys for my '88 pickup, wore the same way. I finally bought
a new lockset and keys from the dealer. I had a '78 Datsun that had the
same problem. One day, I accidently pulled out the key while it was
running. I had to destroy the lock to turn it off, then install a new
lockset...
In both cases, I ended up with two keys, one for the ignition, one for
the doors and gas cover...
Yes, I kept them lubed with graphite, so that wasn't it...
Tom - Vista, CA
Old 06-18-2006, 02:49 PM   #5 (permalink)
Ernie Leimkuhler
Guest
Posts: n/a
View Ernie Leimkuhler's Photo Gallery
In article <1mta925o9tg4le6h8tl33jt0kqrtikhk8k@4ax.com>,
tbl <hate@ThatSpam.net> wrote:
[color=blue]
> Anyone?[/color]
Toyota lock-sets do wear out.
I bought a new after-market ignition lock after my truck got stolen.
The cops pointed out that my ignition lock was so worn out you could
start the truck with a screwdriver.
Any lockshop can order you one.
They are really easy to swap out.
You just remove the plastic shell around the steering column, turn the
lock to the first stop and push a pin into the hole to release the lock
set.
Welding Instructor - South Seattle Comm. Coll.
- Divers Institute of Technology
CWI/CWE
WABO Examiner
Old 06-18-2006, 03:15 PM   #6 (permalink)
Jeff Strickland
Guest
Posts: n/a
View Jeff Strickland's Photo Gallery
2006 - 1988 = 18 years. You don't say how often you use the keys, but
replacing the keys every 6 years seems reasonable enough to me. I wouldn't
worry about it.
> Anyone?
> Thanks,tbl[/color]
Old 06-19-2006, 04:38 PM   #7 (permalink)
tbl
Guest
Posts: n/a
On Sun, 18 Jun 2006 15:56:26 GMT, tbl <hate@ThatSpam.net>
wrote:
[color=blue]
>Anyone?[/color]
Thanks to all who replied.
Unfortunately, after writing the buildup, I forgot to state
my question!
What is the cause of this bizarre, localized wear? I've
been assuming it's something in the ignition switch, and not
the door locks, but that assumption may be no better than my
first post....
Thanks,tbl
Old 06-20-2006, 06:11 PM   #8 (permalink)
Ernie Leimkuhler
Guest
Posts: n/a
In article <156e92t4tj6fi05dbp2fvos5jtpelfl1bt@4ax.com>,
[color=blue]
> wrote:
>[color=green]
> >Anyone?[/color]
> my question!
> first post....[/color]
It is likely that 2 of the pins are sticking.
CWI/CWE
WABO Examiner
Old 06-20-2006, 08:22 PM   #9 (permalink)
Joseph Wind
Guest
Posts: n/a
news:156e92t4tj6fi05dbp2fvos5jtpelfl1bt@4ax.com...[color=blue]
> wrote:
>[color=green]
>>Anyone?[/color]
> my question!
> first post....
>[/color]
Are these Duplicate keys you have made at the local hardware store? or are
these the original keys that came with the truck?
Old 06-21-2006, 07:39 PM   #10 (permalink)
tbl
Guest
Posts: n/a
On Wed, 21 Jun 2006 01:22:34 GMT, "Joseph Wind"
<jpg@gif.com.invalid> wrote:
[color=blue]
>news:156e92t4tj6fi05dbp2fvos5jtpelfl1bt@4ax.com...[color=green]
>> wrote:
>>[color=darkred]
>>>Anyone?[/color]
>> my question!
>> first post....
>>[/color]
>these the original keys that came with the truck?[/color]
One was original, the others from a local lock-shop.
tbl
Old 06-22-2006, 06:28 AM   #11 (permalink)
Phisherman
Guest
Posts: n/a
View Phisherman's Photo Gallery
On Thu, 22 Jun 2006 00:39:16 GMT, tbl <hate@ThatSpam.net> wrote:
[color=blue]
>[color=green]
>>news:156e92t4tj6fi05dbp2fvos5jtpelfl1bt@4ax.com...[color=darkred]
>>>>Anyone?
>>> my question!
>>> first post....
>>>[/color]
>One was original, the others from a local lock-shop.[/color]
This may be due to inferior metals in the key blanks. I have used the
same (Honda) ignition key daily for over 26 years.
Old 06-22-2006, 11:38 AM   #12 (permalink)
tbl
Guest
Posts: n/a
On Thu, 22 Jun 2006 11:28:58 GMT, Phisherman
<noone@nobody.com> wrote:
[color=blue]
>[color=green]
>>[color=darkred]
>>>>>Anyone?
>>>> my question!
>>>> first post....
>same (Honda) ignition key daily for over 26 years.[/color]
This is definitely an unusual type of wear that I'm seeing.
Maybe not unusual for 1988 Toyota pickups, but unusual from
any other keys and locks that I've used. It's not like the
whole key is wearing out, it looks more like somebody took a
hand-grinder to these two spots on opposite sides of the
key. Under a magnifier, it looks to be tiny gouges in the
same (more or less) direction of the long axis of the key.
I'm just curious, but my curiosity is costing us all too
much time.
Back to work, everybody! <g>
tbl
BB code is Off
Smilies are Off
[IMG] code is Off
Getting alarm to chirp procedure - here it is JJMARINE 2nd Generation (2005+) 27 07-13-2007 04:06 PM
Switchblade Key with remote and alarm system (including engine immobilization) autodoodad.com Supporting Vendor Sales 105 08-23-2006 11:05 PM
Ignition Key Programming isandifer Archived Corolla threads 1 09-28-2005 12:00 AM
I need serious HELP!!! problem with key and ignition V6camryTN Camry & Solara Lounge 12 04-21-2005 12:39 PM
My key for the camry is all worn out... strmagiceet Camry & Solara Lounge 9 02-03-2005 07:39 AM
