Re: Faulty TPS or something else?
On 19 Jun 2006 11:30:05 -0700, [email]mixedsig@gmail.com[/email] wrote:
[color=blue]
>I appreciate if someone could help me to diagnose the following symptom
>on my 89 Toyota Pickup, V6, 5spd, 4X4.
>When gas pedal is slightly pressed, the check engine light will flash
>once quickly, and the engine will hesitate/stall when the flashing
>happens. After accelerator passes that slightly pressed position, the
>engine responses normally. Checked idle speed and timing, both are
>fine. Tried to read out error code from computer, if the accelerator
>fully relaxed, the check engine light flashes steadily, which means no
>error codes; if the accelerator if pressed, there is a 51 code, which
>indicates a faulty throttle position sensor. Checked and adjusted TPS
>several times (in specifications after adjustment), the symptom remains
>the same. In the end, I pulled off the connector of TPS, the symptom is
>still there, not better, not worse, can't tell any difference.
>I have the following questions,
>1. Should I press accelerator when reading error code? In other words,
>is the 51 read out while pressing accelerator valid?
>2. What would be the effect of running engine with TPS unconnected?[color=green]
>>From my experiment above, can you tell if the TPS is good or bad? I am[/color]
>leaning to replace TPS, but would like to have evidence showing the TPS
>is dead.
>3. To me, the problem seems to be related to throttle position or RPM.
>If is not due to TPS, what else could go wrong, and how do I test?
>Desperately looking for a clue. Thank you.[/color]
It would not hurt to change it as it could be it. Next thing to check
would be MAP sensor or MAF sensor.(if present on that model)
The SnoMan
[url]www.thesnoman.com[/url]
