Re: 2001 Toyota Highlander Radio help needed please.
Dan, Id say that while yoru amp didnt get wet be the sounds of it your rear speakers may have, if the radio was on this would have caused an output failure (with results sounding like what yourve described)
Output IC's are not cheap to repair but worth doing if system is good enough (sounds like yours is). If your not to worried about it bypass the rear speakers and stay with the fronts, if ya like full sounds get yours looked at (Audio repairer should ID the fault in very short time) and repaired or replaced.
Unless you have insurance to cover the lose and get them to pay for a new one.
"Dan Ward" <danward2318@sbcglobal.net> wrote in message news:QXnmg.70324$4L1.25443@newssvr11.news.prodigy.com...[color=blue]
> OK so we live in Pasadena Texas where it rains 10 inches in 2 hours and I
> woke up one hour too late. Our driveway is pretty steep from house level
> down to street level and the highlander was second in the driveway which
> leaves it closest to the street. When I woke up the water was already high
> but with the angle of the driveway the front end of the Highlander was high
> and dry. The back end was what was in trouble. I opened the front door which
> was still above water level only to find the rear floor boards were wet to
> the touch. I started it up and drove it into the neighbors yard where it was
> level and well above the flood waters.
> Once the rain stopped I started working on it. It seems that all the little
> rubber plugs they put in the bottom of cars are not water tight and as the
> water came up they allowed water to enter the floor of the car. The spare
> tire wheel well had the most as it was lowest due to angle of the driveway.
> Then the rear seat floor boards had about a 1/2 inch of water above the
> carpet which quickly dispersed throughout the car once I got it up on level
> ground.
> Bottom line is the carpet was wet. Seats were dry, no water on doors, no
> water on the dash, no water anywhere but on the floor. I worked my way
> through college in a body shop and know all to well how to remove seats and
> carpets so just as soon as the rain stopped the entire interior came out so
> we could get the carpet out and allow the carpet to dry.
> I was very surprised to find so many cables under the carpet some of which
> wired up to a silver box located a couple of inches above the deck just
> behind the rear seat. It says JBL on it and some inquiries tell me it is the
> amplifier for the fancy radio that comes in the Highlander.
> Here is the part where I get to my questions now that I have explained the
> circumstances and extent of the water level. Everything works just like
> before the rain with the exception of the stereo. left and right front
> speakers just pop and buzz and the rear ones play music but not very strong
> and with poor quality.
> I'm like 99.99999% sure the amplifier never got wet. The carpet got wet but
> amplifier sits well above carpet level. But for sure the cables between the
> head unit in the dash and the amplifier which run under the carpet were well
> soaked and when I started up the Highlander to move it to higher ground the
> stereo was on. Do you think that is when the damage was done? Do you think
> it is just the amp or could the head unit be bad as well?
> The dealer can't explain it but there is a different amp if you have leather
> seat as compared to cloth seats. One part number for cloth. One part number
> for leather. Does anyone know the difference? the dealer doesn't.
> They want $1100.00 for a new amp which is an expensive parts swapping
> expense especially if it isn't really bad. Remember I'm darn sure it never
> got wet. Is there any place that will check these amplifiers out and verify
> it is bad before replacing it?
> Has anyone got any ideas?
> I've called a couple of dealers and got some pretty silly information. For
> example one told me it is their policy to replace all seatbelts and seatbelt
> tensioners. I ask why as they never got wet? Their response was there was
> moisture in the car and you don't want to take a chance on seat belts. They
> also said the replace the amplifier without question. I ask do they check it
> before changing it and the answer was no. They told me they always replace
> all the speakers. I said but they never got wet. Their answer was it is just
> their policy. This entire exchange and I heard similar from several dealers
> makes me think flood damage repair is a racket. Most people have insurance
> and if insurance will pay for it the dealers are going to run up the bill.
> So I'm thinking since I've done most of the work already I'm on the right
> track. I just need to find some help on the radio. Any and all input is
> greatly appreciated and I'd like to extend my thanks in advance to anyone
> who takes the time to reply to this post.
> I've got all the carpet clean and dry and ready to go back in the car. If it
> wasn't for the radio problem this would only be a bad experience. But the
> radio is trying to make it a darned expensive bad experience.
>[/color]
