Re: Tacoma Error Code Help
One, set your newsreader to post in Plain text
Two, your bad sensor is the one after the CAT.
The sensor(s) before the CAT adjust the air/fuel mixture, and they throw a
different code. The sensor after the CAT tells you that the CAT is working
or not. Since the CAT itself has no moving parts, and is a costly repair,
the odds favor a worn/failed sensor over a defective CAT.
"Tony" <ac!ark_10@verizon.n@t> wrote in message
news:oEeng.2663$Wh.909@trnddc04...
Hello Forum,
I have received the catalyst system below thresold error (Bank 1)
(P0402) twice in the last 200 miles. I am going to conduct some research on
the net now, any ideas? It sounds like an oxygen sensor and the truck does
idle a little rough.
Tony
95 Toyota Tacoma 2wd
K&N FIPK Generation 2 w/ Throttle Body Spacer
Fiberglass fenders w/ 31x1050 BFG A/T KO's
