The engine will start but soon as i let off the key it shuts off. I
thought the ignition switch was bad so i truned the key and held it.
Engine still died. Replaced fuel pump, fuel filter, EFI and Starter
relay. Im getting good pressure from the filter. Any ideas would be
great. thanks
Please define the problem. You said that it runs until you let go of the
key, but in the next sentence you said you hold the key and it dies. I'm
confused. Does it die or run if the key is held?
"dvsriot" <tncountrygirl85@yahoo.com> wrote in message
news:1151180677.638615.165110@y41g2000cwy.googlegroups.com...[color=blue]
> great. thanks
>[/color]
Jeff Strickland wrote:[color=blue]
> When you turn the key to start it fires up so you let of the the ket so the starter stops moving. It may run for a second or two then it dies. So i thought maybe it was the ignition that was bad. So I held the key so that starter was still spinning after the motor fired up thinking the ignition switch was bad. But is stalled. so that not the problem. I took a rag with gas on it and put it on the intake manifold turned the key fired up and ran till it sucked all the feums off the rag. it runs when it gets gas. Cant be an ignition problem. its just not getting any gas. I blew out the fuel line and return line there clear. Changed the fuel pump and fuel filter. I dont know what the problem is. would the fuel regulator stop the gas from getting to the injectors? I have good pressure from the fuel filter.
> news:1151180677.638615.165110@y41g2000cwy.googlegroups.com...[color=green]
> > great. thanks
> >[/color][/color]
news:1151199117.793131.76590@p79g2000cwp.googlegroups.com...[color=blue]
> Jeff Strickland wrote:[color=green]
>> fuel pump and fuel filter. I dont know what the problem is.[/color][/color]
Yes, the regulator can shunt the fuel back to the tank, and none of it will
go to the injectors. At idle (high vacuum) the regulator is open so that the
fuel that is delivered by not needed goes back to the gas tank. At speed
(low vacuum) the regulator closes so that all of the available fuel is
delivered to the injectors. A common failure mode is for the regulator to
fail open so that all fuel simply bypasses the injector rail and feeds
directly back to the gas tank.
I have good pressure from the fuel filter.[color=blue][color=green]
>> news:1151180677.638615.165110@y41g2000cwy.googlegroups.com...[color=darkred]
>> > great. thanks
>> >[/color][/color]
>[/color]
> news:1151199117.793131.76590@p79g2000cwp.googlegroups.com...[color=green]
> > Jeff Strickland wrote:[color=darkred]
> the wierd thing is i have little to none fuel return.
>[color=green][color=darkred]
> >> > great. thanks
> >> >[/color]
> >[/color][/color]
How do you know that you have good delivery and no return?
news:1151200530.510180.222240@i40g2000cwc.googlegroups.com...[color=blue]
> i dont have much return fuel comming back.
>[/color]
Can you disconnect the fuel lines at the injector rail?
This test will tell you if the gas is even getting to the rail. If gas is
going in, but none is coming out then you have a blockage. If you have gas
at the filter -- which you insist you have -- and no gas at the rail, then
you have a blockage at the filter, or between the filter and the rail.
Have you isolated the spark system? If fuel is going where it is supposed to
be going, and there is weak or no spark, then you're gonna have problems.
news:1151238829.355113.190410@m73g2000cwd.googlegroups.com...[color=blue]
>I reconnected the fuel filter before checking the retrun line.
>[/color]
I took off the air intake from the manifold and put a rag that had been
dipped in gas covered the intake manifold with it and turned the key.
The truck fired up and ran untill is sucked all the gas off the rag.
Im pretty sure its not a spark problem. And yes im positive that i
have gas comming out the outlet of the fuel filter. so like you said i
guess its plug from there on somewhere. I looked inside the manifold
and the inside look really dirty (all kinds of grit build up). I would
bet that is the problem. The whole manifold is clogged up with junk.
Im taking the truck to a friend (mechanic).
>From what I can see the hose from the filter is crimped to hard line
that is connected to the manifold and can come off. From what I can
see. I got a Chilston book and its crap.
news:1151251703.987395.62920@r2g2000cwb.googlegroups.com...[color=blue]
> guess its plug from there on somewhere.[/color]
Do you have power to the fuel injectors ? Do you have injector pulse when
cranking the engine ?
I looked inside the manifold[color=blue]
>[/color]
The intake manifold only lets in air, not fuel. You say it ran with a gas
soaked rag over the intake so how can the intake be plugged ? The fuel is
supplied by the injectors. Have you checked fuel pressure at the fuel rail ?
Have you checked for power to feul injectors ? Have you checked for injector
pulse yet ?
I use to have a 92 Toyota Pick-up, the idea of fuel getting to the rails is
a good call. You can loosen the bolt at the back of the rail and put the key
in the on position to check for fuel flow. If you have fuel there you can
loosen the rails from the injectors to eliminate a bad rail. Finally you can
hookup a jumper lead to the injectors to check for normal operations.
Unfortunately I sold my factory maintenance manuals so I can not tell you
which lead is hot and the other is ground. Try searching the net.
Tony
95 Toyota Tacoma 2wd
K&N FIPK Generation 2 w/ Throttle Body Spacer
Fiberglass fenders w/ 31x1050 BFG A/T KO's
news:1151251883.623197.52990@m73g2000cwd.googlegroups.com...[color=blue][color=green]
> >From what I can see the hose from the filter is crimped to hard line[/color]
>[/color]
sounds a little like my 92 V6, it won't idle wen it's hot. Does fine at
first startup and during cold months but when the weather gets hot it dies
at stops unless I hold a foot down on the throttle.
> great. thanks
>[/color]
