4runner Caliper Brake Busted Bolt's & Stuck Slide pins - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota USENET Discussion Groups > alt.autos.toyota > alt.autos.toyota.trucks
alt.autos.toyota.trucks Toyota Trucks discussion newsgroup.
Old 06-24-2006, 09:40 PM   #1 (permalink)
youlookhot@gmail.com
Guest
Posts: n/a
View youlookhot@gmail.com's Photo Gallery
I need help badly. I just busted the 2 bolts that hold the caliper by
turning them in the wrong direction. About 3/4 of an inch of each bolt
with head snapped off. Now what do I do?
This is after soaking the slide pins for a couple of days with rust
remover, they also don't budge. I tried using a punch, vise gripping
them in the middle and hammering outward etc.
Is it possible to take apart the caliper while it is still mounted in
order to access what's left of the bolts? Help needed badly, Richard
Old 06-25-2006, 11:39 AM   #2 (permalink)
Ken Shelton
Guest
Posts: n/a
View Ken Shelton's Photo Gallery
Re: 4runner Caliper Brake Busted Bolt's & Stuck Slide pins
[email]youlookhot@gmail.com[/email] wrote:[color=blue]
>[/color]
Sure, take the calipers apart and replace them with reman calipers.
Do not try to reassemble the calipers unless you feel able to
completely overhaul them.
Ken
Old 06-25-2006, 12:47 PM   #3 (permalink)
Guest
Posts: n/a
Just for the record, the reason for having tightened the bolts
instead of loosening.
Facing, I turned counter clockwise, which would have been dandy
had the bolts entered in front and not from the back of the disk, and
snap, crackle, pop!!! (2times)
Am I the only one who ever did this??????????????????
Old 06-25-2006, 01:10 PM   #4 (permalink)
qslim
Guest
Posts: n/a
View qslim's Photo Gallery
Once, no. Twice in a row, maybe. :)
But don't dwell on it. it's broken, now it has to be fixed. No biggie.
BTW, did the caliper slide pin bolts break, or did the big ass anchor
bolts break?
Old 06-25-2006, 09:27 PM   #5 (permalink)
Guest
Posts: n/a
[color=blue]
> bolts break?[/color]
I couldn't loosen those slide pins (92 4runner), I the garage must have
to heat them up to remove them. What broke was the big ass anchor
bolts! I should have suspected something when my 1/4 inch extension
snapped and I had to go to the 1/2 inch. Nothin like havin the right
tool for the job!
BB code is Off
Smilies are Off
[IMG] code is Off
Should I do this or just change the pads? abimanyu Archived Corolla threads 2 09-27-2005 07:48 AM
Changing Front Brake Caliper bcking00 Archived Corolla threads 2 05-11-2005 04:36 PM
SW20 brakes for the do-it-yourselfer ... KAOS MR2 Forum 11 09-18-2004 01:21 AM
Brake squealing/ stuck caliper Zee 1st Generation (1995-1999) 1 07-03-2003 01:36 PM
